Question about Ryobi Replacement Auto Feed Line Spools 3-Pack AC14RL3
How do I get the head off a ryobi 1000w electric line trimmer
I have looked at the instruction manual which just shows you pull the head off but that does not work. Is there something I am missing?
SOURCE: Ryobi 105r replacement line
Look at the top of the spool. Line up the two triangles/arrows by turning the inner wheel The inner wheel is a little smaller that the diameter of the spool and has grip lines scored around it. Just below those arrows, on the side of the spool there is a hole where the line would come out of. Thread the line into that hole until it comes out through a hole on the top of the spool. Then bend the end of that line over and stick it in the little hole next to the hole it came through. That will lock it in place. Pull on the other end of the line to tighten it. Now turn that inner wheel and the line will wrap around on the inside of the spool. When it stops and you can't turn it anymore, it's full. Cut the line off about 10 inches or so outside of the spool.
Posted on May 19, 2008
SOURCE: Ryobi Electric string trimmer
TJ, I've had the same problem since yesterday and I found the solution (lots of googling - that's how I found your post BTW).
It turned out that the switch malfunction is a common problem.
The part number for the FA3-4 switch is:
ut41002a-36 ("switch assembly")
Available here (thru Amazon):
http://factorylawnandgarden.com/product/553902/B000PLVCX8/SWITCH_ASSEMBLY_UT41002A_36/
It's a Homelite part, which is identical to Ryobi.
Here is the manual showing it (part 6):
http://www.m-and-d.com/pdfs/ryobi_tool/RY41002.pdf
Here is the thread with the solution:
http://www.ryobitools.com/dc/dcboard.php?az=show_topic&forum=112&topic_id=597&mesg_id=597&page=3
HTH,
Adi
Posted on Jun 25, 2008
SOURCE: Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Posted on May 18, 2009
#1 Taper
  • 1040 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • 885 Answers
SOURCE: Ryobi string trimmer RY34420 has a non retracting
The starter assembly is between the motor and boom so you have to remove the boom from the motor housing. Usually one nut & bolt at the nose of the starter housing. There may be another lock bolt. You shouldn't have to remove the throttle cable and leads but it depends on how tight the factory installed them. Remove the starter housing. If you're real lucky all you have to do is pull some starter rope up past the pulley and wind the pulley in the direction the rope pulls back into the housing. You have to pull the rope around the pulley as you wind it. If the spring catches and builds tension you're good, wind it four or five times or enough to fully pull the rope back in. If the spring doesn't catch or releases every two or three turns it has to be replaced. You may have to replace the spring and container (PN638033001) and/or the easy start assembly (PN310022001).
Posted on Aug 31, 2010
What is the proper configuration of the ryobi p2200 string trimmer head assembly?
Ryobi P2200 18 Volt Hybird String Trimmer Parts
Find Part By Symptom on right side
Select "Trimmer line feeds too much / continuous"
Will show you list of parts to hopefully fix you problem
Jul 22, 2017 | Ryobi Garden
Repair manual for ryobi line trimmer rlt900
Jerry,
That number is not the model number for the trimmer, which always starts with RY. It is the number for the "bump head assembly" which is considered an accessory. They made 3 for this application as follows:
  • Bump Head Assembly, RLT1000, RLT900, RLT1004K
Once you determine your correct trimmer model number you can go to the link below and find your manual. Hope this helps.
RYOBI Product Manuals
Mar 29, 2015 | Ryobi Garden
How do I get the old line trimmer spool off of my Ryobi 18 volt cordless trimer
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
1989 ford f150 missing
Well it could be an injector, or a valve. But he should have fixed a sticking valve when the head was off.
A basic compression test would show if it is a sticking valve.
May 15, 2013 | 1989 Ford F 150
How do i get trimmer line holder cap off my electric ryobi trimmer rlt 1038
Hi, I wished I had read this before I bought my rlt1038, I used it for
8 mins and 1) long grass caought around the drive head, 2) I tried to undo the screw holding the line head. Fortunately I have a wide pair of foot prints to go across the line head and a central heating pump adjustable spanner- after 5 mins I had undone it. Yet another bad design !
Good Luck
Mar 16, 2013 | Ryobi 15" Electric Factory Reconditioned...
RYOBI ELT1100 ELECTRIC LINE TRIMMER DRIVE SHAFT PROBLEM
You can find it here
https://www.manualslib.com/manual/640551/Ryobi-Elt1100qfa.html
Oct 01, 2017 | Ryobi Garden
I need instructions to reload line into a Ryobi 725r string trimmer.
See pages 16, 17 and 18 of your manual for the instructions.
http://dl.owneriq.net/0/0ef35b42-433c-4be9-9621-4e761571c41f.pdf
You will need Adobe Reader installed on your computer to view this. If you don't have it, it is a safe download and it is free.
May 08, 2011 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Replacement Auto Feed Line Spools 3-Pack AC14RL3 Logo
23 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
