Question about Eclipse Audio Players & Recorders
I have an Eclipse Model T180 mp3 player. I recently put music on it, but when I go to play music or pull up the music menu, it displays "Disk Error!" I can onlylisten to the FM Radio, and it won't pul
I have an Eclipse Model T180 mp3 player. I recently put music on it, but when I go to play music or pull up the music menu, it displays "Disk Error!" I can only listen to the FM Radio, and it won't pull up on my computer. If it helps any, instead of syncing the music directly to the Eclipse through media player, I put the files on it directly from my library (a.i drag and drop), and this works perfectly fine with all my other music players. I did this the previous time I put music on the darn thing, and it worked fine as well. I just thought I might as well add that tidbit in case that had anything to do with the problem. Any ideas on what I should do?
SOURCE: "playback error"
Try replacing the songs, like, putting them on again. I don't know 100% if it will work but mine had the same problem and this worked.
Posted on Nov 14, 2006
Jessamole
SOURCE: Sandisk sansa e200
I had this same problem on my sansa and tryed the previous solution with no luck. Out of frustration i email the sansa technical support. Try these steps to format the player: -Turn on the player and access MENU > SETTINGS > USB > MSC - Once the player is set to MSC mode, reconnect it to the computer and open the My Computer window. - Once you see the Sansa icon in the My Computer window, right-click it and choose FORMAT - In the Format window, choose FAT 32 and make sure that Quick Format is NOT selected, then choose START -Once the format has completed, disconnect the player from the computer to allow it to refresh. If you plan on using Windows Media Player to transfer files, return to the USB menu and set the player to MTP mode. Otherwise, leave the player in MSC mode and you can now resume transferring files. Formatting your player will deleate all files but you can putt them back on!!! Best of luck!
Posted on May 09, 2007
SOURCE: Sylvania SMPK8854B MP3 Player File Format Error
hey, the way to do it is to install that little cd that came with it and save them to your desktop…now when you see them appear open the AVI converter…this will bring up a screen that asks to add the videos you want to convert and also a destination…just browse that and find your video that you want to convert and then make the destination the mp3 player and click convert…and whallaa! it will be ready to look at in your mp3 player…takes some playing with, but you’ll get it…God bless! <><
Posted on Jan 04, 2009
SOURCE: mp3 player says ''no file'' after repeated Sync attempts
I have one of these too and finally figured it out! If you push the menu button on the side, you get a menu that you can scroll through with the left/right arrows on the face. The music icon should be first in the list, but if not, scroll until you get it highlighted. Once highlighted, push menu again to select it. My trouble was in not realizing that the menu button is also the select button!
Posted on Mar 25, 2009
SOURCE: I recently recieved a Hip
I have... had the same issue. You have to go to "set up", then "system tools", then "reset", then "yes"... next time fork out the few extra bucks and buy a better product.
Hope it works for yours too.
Posted on Mar 26, 2009
How do I download songs on my eclipse mp3 player
Things You'll Need
Microsoft Windows 7 computer with an open USB port and iMesh installed
USB cable compatible with Eclipse MP3 players
Instructions
  • 1 Plug a USB cable into the Eclipse MP3 player. Plug the other end of the USB cable into an open port on the Windows 7 computericon1.png.
  • 2 Click the "Start" button on the Windows 7 desktop taskbar and click "Computer" in the menu that appears. Click the "Music" item located in the left pane of the "Computer" window that appears. Double-click on the "iMesh" folder. For Windows 7, XP and Vista. Recommended. Download Now.
  • 3 Click the "Start" button on the Windows 7 taskbar and click "Computer" and then double-click on the "Removable disk" icon that represents the Eclipse MP3 player device. A window will appear displaying the contents of the Eclipse MP3 player storageicon1.png area.
  • 4 Right-click on a music file in the "iMesh" directory that has the "mp3" suffix, and click "Copy" in the menu that appears.
  • 5 Right-click on empty space in the "Removable disk" window and click "Paste" to copy the music file to the Eclipse MP3 player device. Repeat for each file you wish to download to the Eclipse MP3 player.
    To copy multiple music files at one time to the Eclipse MP3 player, press and hold the "Shift" key on the keyboard. Click once on each file you wish to copy. Right-click on one of the highlighted MP3 music files and click "Copy" in the menu that appears. Right-click on empty space in the Eclipse "Removable disk" window and click "Paste."
Oct 21, 2014 | Audio Players & Recorders
What do I do to Eclipse fix mp3 when it diplays "Disk Error!" upon attempting to play music?
Presumably the error is caused by a hard disk drive? In which case the hard disk will need to be checked. If there are options to do this use them. Otherwise the drive might need to be replaced.
If you bypassed the normal way of putting music onto the drive, then it might have corrupted the drive.
If there is an option to reformat the drive that might work. Or if there is a factory reset, that might correct it.
If you have music stored on the drive, which is not found anywhere else, then I think it will have been lost for good.
May 27, 2017 | Eclipse Audio Players & Recorders
What should I do when Elcipse mp3 displays "Disk Error!" upon trying to play music?
The players laser reader has burned out, your best option is to replace the deck.
Apr 05, 2017 | Eclipse Audio Players & Recorders
How do i download music?
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Dec 22, 2012 | Eclipse T180 MP3 Player
How do i download music from my computer to a eclipse T180
I got a eclipse t180 aswell and to download music you just go to any site I go to google.com and type in for ex: "Beyonce - single ladies mp3 download" then you can go to any of those you feel like choosing I usually pick "mp3ye.eu or dilandau.eu" you have to look when saving the song that it is in "VCL Media File (mp3.)" or otherwise it won't play when you download it.
Dec 05, 2012 | Eclipse T180 MP3 Player
Empty disk
Nov 24, 2012 | Eclipse T180 MP3 Player
Why do i get format error when i put songs from a cd on the eclipse?
1. Why do i get format error when i put songs from a cd on the eclipse?
= This is probably because the format that your songs are currently in is not supported by your device. Supported devices on the Mach Speed Eclipse 180 MP3 player are: mp3, wav, and wma. If your music is for example filename.cda, it won't be able to play because of the file format being .cda.
2. I also see the song on the eclipse but it says drm protected and will not play the song.
= When ripping your music, check your ripping options in whichever ripping software you are using that protecting music files is off, this may be the reason why your music cannot play - it may be protected to only play on the computer that ripped(recorded or duplicated) the song.
Sep 17, 2012 | Mach Speed Eclipse 180 MP3 Player
File error
With your mp3 player not playing any music, press and hold Search/Menu until the menu comes up (1-2 seconds). Scroll to the last chioce, which is Advanced Menu. Press your Play button to select it, select Format, select OK, and your mp3 player will be formatted. This WILL erase all of the music that you have on there, but reload it all with SonicStage, and you should be good to go.
Aug 09, 2006 | Sony NW-E507 MP3 Player
Top Eclipse Audio Players & Recorders Experts
Oloyede Monsuru
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
