SOURCE: Weber Genesis Silver B Grill lights, but does not heat
Perhaps. There is a built in safety in the regulator. It is there to stop the free flow of gas in case of a leak. Of course there could be a leak but more than likely it's a case of lighting the unit without taking very sure basic steps.
Be sure you turn off the gas tank and the valves. Then, only open the first valve (do not open the others at all yet) and then light via the switch. After the first bar lights up wait perhaps ten seconds and then do the next two. See if that helps....it does for me.
pops
SOURCE: Weber Silver Genesis C regulator purging gas after reset process
This could be caused by a couple of problems. First the regulator could be bad, or the tank is getting to hot. Which causes the relief valve to open and release pressure. This will happen when weather outside is hot.
SOURCE: Can I replace the thermometer on my Weber Genesis
Lightly tap on the pointy end of the thermometer, and it should snap out of the bracket that holds it. Snap replacement into position...
SOURCE: Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
SOURCE: How to replace ignition switch
where does the ignitor switch plug into ? genesis ....came unpluged
