Question about Tascam Dp-02cf Digital 8-track Recorder
Can't load a song on Tascam Portastudio - Tascam Dp-02cf Digital 8-track Recorder
  • 189 Answers
SOURCE: Tascam DP-01 FX/CD Digital Portastudio
Here's a link to a forum where someone else encountered the same error. Seems it was due to running out of disc space in that instance.
http://www.tascamforums.com/lofiversion/index.php/t10089.html
Posted on Jan 03, 2008
ginko
  • 19396 Answers
SOURCE: tascam 2488 digital portastudio
Your HD risk to be corrupted, probably need to be removed and tested on a different device, I see if I can find the schematics
regards
Posted on Mar 08, 2008
  • 189 Answers
SOURCE: Tascam Portastudio DP-1FX/CD
This is basically an error message which indicates that the Tascam timed out while waiting for the drive to spin up. Usually an issue with the drive motor not getting the correct amount of power.
Primary suspect is usually the power adapter.
Cheers
BD
Posted on Apr 23, 2008
  • 189 Answers
SOURCE: Tascam Portastudio 424 Manual needed
Try this page: http://www.tascam.com/products/424mkiii;9,17,141,19.html
Regards,
BD
Posted on Apr 25, 2008
  • 189 Answers
SOURCE: load imported songs on tascam dp02 cf
Make sure you have the song loaded first. In this case it sounds like you are importing into a new song, so make sure that you have a new song created and loaded prior to importing.
Then go to the menu by pressing the 'MENU' sutton and from there select 'WAVE' and then 'IMPORT TRACK'. You'll see the list of wav files on the fat partition of the CF media displayed. Select the wav file with your beat track on it (use the DATA DIAL or up/down arrow buttons to highlight the right wav file) and press the 'YES/ENTER' button. You'll be prompted for the track to import into. Select Track01 and press the 'Yes/Enter' button again and the WAV file will be read and inported into track 1.
Please note that the wav file should be a 44.1 kHz, 16-bit and a mono wav before trying to import it. If the beat track was created as a stereo wav you'll have to go into a wav editor like Audacity and resave the file as a mono wav file first. Also for a wav with a bit rate higher than 16-bit, the DP-02 is going to truncate the bits rather than dither and this might effect quality adversly so you might want to make sure that the file is properly saved as 16-bit prior to attempting an import to avoid this.
Hope this helps.
bd.
Posted on Jan 12, 2009
How do I set my Tascam DP-32 to record 24 bit 48kHz?
Dustin, just go to song in the menu , click the arrow to song load, create etc. cursor to song create and it will give you the option of 16 or 24 bits just turn the cursor wheel then just cursor down with the button and select 44.1 or 48 kHz . Then cursor up to song load and push the right arrow and it will load your song with the settings you have selected. Very good recorder once you learn your way around on it. Joe
Nov 12, 2014 | Tascam DP-32 32-Track Digital Portastudio
How do i load a song from a cd onto tascam 2488 mkII?
Although I was a factory authorized service center for Teac and Tascam, this is a much later product than I'm familiar with; no problem however.
If you have your owner's manual, the procedure will be listed there. If you no longer have the manual, just Google Teac, in Montebello, CA. I'm quite sure it will be our their website.
Jun 12, 2014 | Tascam 2488 Portastudio Multitrack...
How do you get back to songs previously recorded?
Turn on the 2488. SONG then LOAD then you should see a list of your songs on the screen. If you do not, they MAY be (some or all) on a different partition. See the manual concerning the partitions and how to get to them as it is a simple matter.
Hope this helps.
Apr 07, 2009 | Tascam 2488 Portastudio Multitrack...
Transferring songs onto new CF card
You'll have to create backups of your songs and transfer those backups using USB to your PC. Then with the 8 GB card inserted you can reimport them to the Tascam (USB) and restore them to the current working song which will then get saved on your 8 GB card. Do this for each song and then you can discard (delete) those backed up song files while connected to the PC.
Hope this helps.
bd.
Feb 07, 2009 | Tascam 2488 Portastudio Multitrack...
Play and Record button not working
I have the same problem with all three of my Tascam 2488 MKII's.
It's a software problem and starts to show up when the harddisk gets full.
Backup your song files ( something you have to do anyway ) and then reformat the entire hard disk.
Then restore the songs you were working on lately.
Before doing this rather huge task, you can copy your latest song to another partition and go on with this copy.
This is only a provisional solution.
Hope this helps !
Best regards
Jan 24, 2008 | Tascam 2488 Portastudio Multitrack...
Dec 04, 2007 | Tascam DP01 All-In-One Recording Package...
Cant erase song
Is the song you are trying to erase the only song on the partition? If so, create a new song then try to erase.
Oct 10, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam Dp-02cf Digital 8-track Recorder Logo
54 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
