Question about Cyberhome CH-DVD 300 DVD Player
1/3 of picture from right side is on left side
I have a unit that has 1/3 of vedio on right side cut off and is put on the left side,and if i leavr unit on with no dvd ,thr cyberhome logo will start drifting
  • 10,594 Answers
Go to dvd setup menu and change video out settings that seems unmatched with your TV
Cyberhome logo runs on screen after a while if player left for few minutes, its feature calls Screen Saver and its good feature that saves TV screen to merge / burn permanent image.
Thanks.
Posted on Jun 23, 2009
Akai ct2121 no full raster ,left side cutting ,right side picture folding
power supply may not delever the proper out put.
check all the power out put supply and currect.
Sep 14, 2011 | Akai LCT2715 27 in. LCD Television
I have an older JVC Shelf Unit with the main control unit in the middle and a left and right side speaker that contains a built in subwoofer on each side, lately the Speaker cuts in and out at higher...
It's one of three things things:
First, examine where the speaker wires are plugged into the receiver. Are any of the copper strands touching one another? If so, remove the excess stripped wire and reinsert it. Problem solved.
Test two: bad speaker. to test, swap the speakers (hook the right speaker to the left speaker jacks and the left speaker to the right speaker jacks). If the RIGHT side now cuts out, you have bad speakers.
If the speaker on the LEFT jacks still cuts out, your amplifier is going bad (which could cost between $50-$200 to repair).
Jul 01, 2011 | JVC Audio Players & Recorders
My 3'' by 1'' label now prints in the middle to the right and cuts of info.
So the left side is blank ? Usually caused by an imbalance across the printhead. Check the toggle pressure on the left side. Each toggle has a dial on top for adjusting the down pressure. Probably less pressure on the left than the right. Quick test would be to use your finger to put some down pressure on the left side of the printhead while printing. If the print is there, you have your answer. If still no printing, then something else is happening.
Hope that helps !
Apr 28, 2010 | Zebra S4M Thermal Label Printer
The sides of the screen are cut off
Please try using the Auto adjust functionality on the LCD TV unit itself.
Jan 07, 2010 | LG 42LC2D 42 in. LCD HDTV
How to refill brother lc61 ink cartridge
Trust me, this is the BEST way and the EASIEST way to refill black and color LC61 or LC65 inkjet cartridge from Brother. See the pictures
1. cut the plastic part (see picture). You can use a utility knife or a steak knife (very easy to do)
2. make a hole on the left or right side (NOT in the midle) and do it straight and don't go deep (see picture)
3. poor the ink with your refill kit and do it straight and don't go deep because the inner side of the cartrigde is made of cheap plastic (like a plastic bag) and you don't want to perforate it
4. put your plug, tape, hot glue or what ever you have to seal the hole.
5. put the cartrigde back in your printer, do a print test and that's9d5859a.jpg8c316c6.jpg it !!!
Jul 08, 2009 | Brother Office Equipment & Supplies
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Shifted Picture
Yes. This problem comes about by actually pressing the center ring accidentally during normal viewing. Just press and hold the left or right side of the ring until the pciture straightens itself out again (if the black portion of the screen is to the right of the picture, press the right ring; if it is to the left side, press the left ring).
-Tha Mp3 Doctor
Feb 04, 2008 | Philips 51PW9363 51" Rear Projection...
MP3 problem
i bought the unit used without the software. pictures and vedio work fine but I need software to record music to SD card. any sugestion?
Dec 25, 2007 | Panasonic SV-AV30 e-wear Camcorder
Cyberhome CH-DVD 300 DVD Player Logo
21 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
