Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Much slower warm-up time?
I've started having this problem about 2 weeks ago. Once power is turned on, the set takes over 2 minutes to warm up to full screen color/brightness. It used to be much faster. I've had it for over 2 years, and want to know what is happening and how I can resolve it?
Thanks for a prompt reply.
Snow01cap@gmail.com
    Novelist:
    Scholar:
  • 96 Answers
Yes the bulb is getting harder to start, don't worry about it, ha get it Dont' worry about it,
I would start by getting a new bulb, it will eventualy stop.
Oh MMM your welcome
What about Bob
Posted on Mar 01, 2008
Poulan Leaf Blower
you may need to turn the Hi screw on the carb in 1/4 of a turn. Make sure the gas and mix are fresh.
Jul 22, 2013 | Poulan Garden
2008 Dodge Ram starts till warm then shuts off like the key was turned off, after a minute will restart and then shut off again
most likely crank sensor on top or right side of transmission is bad. tap on sensor lightly to see if vehicle starts.
Apr 22, 2013 | Dodge Ram 1500 Cars & Trucks
2008 Chevy Suburban LTZ 1500 4X4 Gas suts off after I just start filling up
Usually a venting problem in the filler pipe or with the gas tank.
Pressure inside the tank as to escape as fuel is being added.
Jan 22, 2013 | Chevrolet Suburban 1500 Cars & Trucks
My 2000 expedition will not start just clicks under dash but doesnt always first time it happened suddenly came home from store turned motor off got back in 10 mins later just clicked sat for a day or two...
This is a classic sign of a bad starter. When a starter is on its way out, it will usually start when cold. Once it heats up after a short trip or 2, it takes more and more power to get the starter to turn. If the truck will start with a jump when warm, you've confirmed that you have a bad starter.
Apr 27, 2011 | 2000 Ford Expedition
About 2 weeks ago my dell 42" plasma started
change your tv main board, your tv board was broken
Jan 16, 2011 | Dell W4200 42 in. HD-Ready Plasma...
this problem is from power supply section, check your power supply, change it with new one
Jan 16, 2011 | Dell W4201C 42 in. Plasma HDTV
55,000 miles. new battery. new air filter. original spark plugs. runs very smoothly after starting. engine started having to turn over more then about 2 weeks ago. idle speed is slower I noticed. on...
You may have sludge in the idle air bypass valve and or the throttle blade is sludged up, clean them with an approved spray cleaner, call honda and ask what they recommend. You may also have a loss of fuel press due to a defective check valve in the fuel pump, in that case cranking time is increased quite a bit, as much as 5 or 10 seconds.
Jul 13, 2008 | 2005 Honda Civic
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
LD 37LC7D
This set has a modification that needs to be done. It will also start turning on by itself and changing channels rapidly. It's two weeks old. Take it back to the Retailer or if that is not an option contact LG at 1-800-243-0000 to get a local servicer in your area.
Aug 18, 2007 | LG 42LC2D 42 in. LCD HDTV
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
