Question about Garden
Echo chainsaw hard to pull start. - Garden
2 Suggested Answers
  • 5 Answers
SOURCE: HARD TO PULL CORD WITH SPARKPLUG IN CHAINSAW. IF
sound like hydraulic lock,try leaving the spark plug out and pull it quite a few times with the spark plug hole facing the ground, this should shoot the offending fluid out.
might work ?
Posted on May 01, 2009
Echo t330 chainsaw has compression lock cant pull start cord
remove your spark plug and try to pull over. if it still won't turn over then you will have to decarbon your head or you have vapor lock so then with plug removed pull recoil and if fuel sprays out of plug hole keep pulling over until there is no more spray from hole. clean plug off. reinstall and try starting
Oct 14, 2014 | Echo Garden
Echo CS346 Very hard to pull starting rope, feels like it has 3 detents. However, with spark plug removed, it pulls smooth and easy. Could I have a stuck exhaust valve.
Most chain saws don't use "valves" but just have an exhaust port from the side when the piston is down. You MAY be just carboned up in the cylinder head so compression is too high causing extra hard force to go over the center. Maybe you are running with too much oil mix or there could be a failure of the con rod bearing.
Nov 22, 2011 | Echo Garden
I have a echo cs-341 only way it will start is if the muffler is off. any ideas? i did pull the screen still did not help. thanks
I guess the muffler is blocke inside with carbon, burn it out with a small gas torch, the carbon will burn and eventually fall out.
Jul 06, 2011 | Echo CS600P Gas Chainsaw 20 Inch
Echo cs-3400 wont start . no spark. what are the primary and secondary coil readings?
if you have no spark
check for faulty plug 1st, then pull kill wire off at kill switch, then check for grounding ht lead ,
then pull kill wire off at armature , if still no spark most likley faulty ignition armature
i suspect the part number you need if its type 1 is 15662639130
replace it and set air gap and reassemble and test
here is web site for parts
http://www.ereplacementparts.com/echo-cs3400-type-chainsaw-parts-c-35043_35970_36021.html
or you could try www.partstree.com , go to echo saws , then find your model
cheers hope it helps
pauly 46
Jan 28, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
BRAND NEW ECHO CS-600P HARD STARTING, HAVE TO PULL THE RECOIL LIKE 20 TIME BEFORE IT WILL START.
Are you pumping the primer bulb until fuel flows into the bulb, setting the choke, and the fast idle is being set? Set the choke at half position after the first 'pop' and don't touch the throttle until it starts running. If you are doing these things per the instructions, take the machine back for warranty adjustment. Hope this helps!
Nov 03, 2010 | Echo CS600P Gas Chainsaw 20 Inch
Echo weed eater, edger and blower wont start.
TRY TAKING THE MUFFLER OFF AND CLEANING THE SMALL SCREEN OR JUST REPLACE THE SCREEN
May 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Chainsaw won't start
Time to get out your trusty tool kit. Remove the side cover assembly and look at the recoil assembly. You should see a pair of fingers that when you pull the cord move toward the center. If the fingers are there and not broken, make sure they move when you pull the cord. clean them if dirty or have foreign objects (like sawdust) around them. If the fingers are broken, replace them. You should be able to purchase them from your local saw shop.
Apr 18, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
