Question about Ovens
Oven 150 degrees off - Ovens
  • 10,865 Answers
Hi . i can help.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
  • Posted on Jun 23, 2009
    Lg oven f11 code
    you need a qualified repair facility to check it out. the thermistor could be defective, or the control board.
    Mar 24, 2018 | LG Ovens
    My oven is loosing temperature
    To me it sounds like the heating element is starting to go, I would suggest that you replace that and see how it go there after.
    Feb 10, 2012 | Ovens
    Bosch gas oven heating slowly - takes about 1 hour to reach 150 - 200 degrees. When trays placed in oven, temperature decreases cooking very slowly
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or Oven not Heating
    Oven Problems Replacing the Igniter
    heatman101
    May 19, 2011 | Bosch HBL 5032 Electric Single Oven
    Oven turns on, but w2ill only heat up to about 120 degrees, you can reset and increase temp, but will only go to 150 degrees. Broiler works, but oven anf d oven clean do not work
    If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
    Oven Problems Electric Oven is Heating Slowly or Poorly
    heatman101
    Jan 18, 2011 | Amana Ovens
    My oven won't heat above 150 degrees. Is this is
    this can be problem with the temp probe.and or the control board if your unit is equipped.
    Jan 23, 2010 | Ovens
    Amana Oven ARG7800E - Oven will only heat up to 150 degrees.
    u sure the flame is lighting sounds like it isn't make sure u physically see the flame u might just be seeing the glow of the igniter if it doesn't light more than likely the igniter needs to be replaced
    Jun 27, 2009 | Ovens
    Oven not achieving correct temperature, 50 degrees too low
    Thermostat is not working properly and needs replacement.
    Apr 14, 2017 | Ovens
    Oven cuts out
    Most of the time it is a temp sensor in the oven. We bought a service manual at houseneeds.com and fixed ours.
    Nov 30, 2008 | Ovens
    Ovens Logo
    365 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
