Question about Toshiba Televison & Video
47hl167 se va la imagen - Toshiba Televison & Video
4 Suggested Answers
pazman
  • 81 Answers
SOURCE: color calibration
I'm sure that there is a reset on the menu for the color, then you can set to your likings.
Posted on Apr 09, 2008
  • 2336 Answers
SOURCE: Por Favor me gustaria que
Podrias proporcionar el modelo completo de tu plasma?
Cuando proporciones el modelo te indicare donde esta la falla y tambien donde comprar la parte(s) para reparar tu TV.
Posted on Sep 12, 2010
welcomejee
  • 10594 Answers
SOURCE: mi televisor comenso con
Your tv got leaky capacitors problem in Hyper Module / Board, since tv is an old model so new hyper module would not be available any more.
Only option left is to replace all bad capacitors in hyper module that requires good soldering skills and proper tools, it is not user level repair and should be done by tv repairman, check with your local tv repair shop if they agree to repair it.
As I explain, tv is an old model so may be repair/ labor cost got more than tv worth so ask repair estimate before handing it over for repair.
Hope these info will help you.
Thanks.
Posted on Aug 11, 2011
Mi problema es con mi mi televisor mitsubishi vs-50501 enciende y cuando va a entrar la imagen se apaga a veces si entra y se ve medio rara como que tiene dos imagenes un poco separada o se ve la imagen...
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Dec 19, 2013 | Mitsubishi VS-50609 50" Rear Projection...
Se queda sin color la pantalla solo se ve la imagen pero sin colores sdolo en blanco es una magnavox de 32 pulgadas griz
Hello
Ya sea que est? viendo una pel?cula o un deportivo
caso, el televisor dispone de v?deo autom?tica
ajustes de control emparejados por su programa actual
de origen o contenido. La caracter?stica SmartPicture
restablece r?pidamente los controles de v?deo de su televisor para una
n?mero de diferentes tipos de programas y la visualizaci?n
condiciones que pueda tener en su casa. cada
SmartPicture configuraci?n se ajustan en f?brica para
ajustar autom?ticamente el brillo de la TV, el color,
Imagen, nitidez, tinte, la temperatura,
DNR, y los niveles de contraste +.
0.1 Pulse el bot?n inteligente de la imagen
en el control remoto. la corriente
Establecer SmartPicture aparecer? en la
centro de la pantalla.
2 Pulse el bot?n inteligente de la imagen
varias veces para seleccionar ya sea personal,
Pel?culas, deportes, d?bil
Se?al, o la configuraci?n MULTIMEDIA imagen
Aceptar
Jul 12, 2011 | Philips Magnavox 27MS343S 27" TV
Por Favor me gustaria que me respondierais a la mayor brevedad posible y en español. Mi lg pdp42,estaba funcionando perfectamente y de pronto se escuchó un ruido,como cuando se va la luz,como si...
Sep 12, 2010 | Televison & Video
La imagen se pierde y se frisa no trabaja el control
usted tiene problema con el optical block , desafortunadament esta reparacion cuesta al rededor de $400-$500
Apr 13, 2010 | Samsung HLP6163W 61" Rear Projection...
La imagen no se ve .. el display tiene luz . el sonido anda bien
Hola ... Buen dia ...
He recibido el correo ...
Bueno, el problema aun existe ... he revisado las tensiones de fuente , por lo que pude ver hasta donde pude, ya que no tengo ningun manual , es solo lo que vi , todas estan presentes ... tambien revise los reguladores de tencion de la placa que esta hubicada en el medio a la derecha de la fuente . y estan bien ... para forma de ver la principal sospechosa de la falla , por que el sonido y sintonia estan bien .. la iluminacion de la pantalla tambien . y no tengo nada de nada de imagen en ninguna condicion ..
EL ofrfecimiento que me hacen seria interesante ... pero no poseo cuenta bancaria , no targeta de credito para efectuar el pago ... por eso no me asocie ... mi momento economico es duro ...
Lo que venia arreglando este ultimo tiempo son MINILABS que hacen las fotografias. pero la enorme rececion den Argentina daño mucho ese mercado .. En la T V LCD, es la primera vez que incurro ...
Quedo agradecido por la atencion y en espera de vuestro comentario ..
Apr 14, 2009 | Televison & Video
TV Konka modelo K2038U. No enciende.
Muchas televisiones tienen reguladores ,si ese regulador no esta dando lo que tiene que dar hay que cambiarlo,tambien puede haber un corto en la linea y eso esta manteniendo bajo el voltaje,hay que chequiar los filtros(capacitadores).Suerte
Sep 06, 2006 | Konka K1369U 13" TV
Televison & Video Logo
12 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
