Question about Pyle PLTS76U Car DVD Player
How to wire a amp for video - Pyle PLTS76U Car DVD Player
96, ford mustang, after market radio installation help! where to plug the amp remote wire for amp
The blue wire is a triggering wire of a low amp power for Amps or a power antenna. If it draws too much power (gets hot), use a relay for more power directly off the battery.
e,g..2 amp radio output and if the amps need 1.5 amp each that's 3 amp. Need a a relay.
Jul 17, 2017 | Ford Car Audio & Video
Whats colors are what for my weatherproof security camera it has four wires
Red & Black is the power wires (Red +) & (Black -). The other two wires are probably the video signal (normally green & white). If you have a separate coaxial connection for the video signal, the other two wires could be for zoom lens control.Look up the make & model on line and check out the specs. Hope it helps. Ed
Oct 05, 2012 | Lorex SG6153 / Weather Resistant Mini...
Am not seeing a remote wire to run to my amps with the pyle plts78dub
If you are still looking for or current looking for the remote wire. This model has a blue wired that should be labeled power antenna this is the remote turn on wire. This is what you need to run remote power to your amplifier.
Sep 24, 2012 | Pyle PLTS78DUB Car Video Player
INSTRUCTIONS FOR (EMERSON DVD/VCR) MODEL EWD2004
it sounds that your tv has no audio/video input jack so you don't have place to insert the rca cable. what you need is an RF converter where you can hooked up the 3 cable wire for audio( L/R), video.then the other end you need to use an RF plug with wire that you can plug into the RF tuner of the tv and the other end to the RF converter.hope this can helped thanks for using the fixya.
Aug 12, 2012 | Televison & Video
I have a Sony tv and Panasonic Video Recorder. I have reconnected after move and now get Sound but no Picture when I try the Video tapes. When I press the Video Plus to record it takes me to an AV2 screen...
may be the audio/video cord(wire) are not put in the right sockets, try to reconnect & see yellow wire connected to yellow socket, white to white & red to red. otherwise replace the core.
Aug 19, 2011 | Televison & Video
PANASONIC MD NV 10000
i do not understand,do you connect all these cables at the same time?If yes is wrong ...Just connect in a well known pc the fire wire cable and power on camcorder.If pc doesn't capture video,THEN look after editing program...
Jul 27, 2009 | Panasonic NV-MD10000 Camcorder
My cd player does not have an external amp wire but has amp connect jacks how do i hook it up to my amp?
You should plug your RCA's from your amp to your radio output. Then you should take the blue power wire for the amp and splice it to the blue wire on your cd players wiring harness. The blue wire is for an automatic antenna or for 12v current for a amp.
May 04, 2009 | Lanzar SDBT75N Car DVD Player
CONNECTING AN AMP
Amp is powered by a main power wire to the battery, ground to metal chassis, and a remote wire (usually blue) from the D player to the remote in on amp. RCA's from CD player to amp as well. Not sure what you mean by "no amp wire on harness". Let me know so I can give you a more definitive answer.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 24, 2009 | Pyle PLTS76U Car DVD Player
NO SOUND!!!
On the Back of the DVD Player there are probably two blue wires. One is for the amp turn on and the other is the power antenna wire. Whats happening is when you turn the radio on the blue used for the power antenna is trigger and puts out a 12vlt signal to push the power antenna up.. So when you look at your factor car harness..be sure the wires are correct..on one wire is gonna be for the amp turn on and the power antenna. use the amp turn on the to a different wire that is connected to the factory amp. You can get a diagram from your dealership. With the correct wires in the right positon, you will get sound out of your vehicles speakers.
Oct 25, 2008 | Car Audio & Video
Pyle PLTS76U Car DVD Player Logo
29 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
