Question about Parasound Audio Players & Recorders
How do I fix FM problems with Adcom pre amp?
Adcom tuner pre amp FM fades in and out, I understand it is a common problem?
  • Parasound Master
  • 3,382 Answers
The problem is your RF signal, it is to low.
Posted on Nov 27, 2014
4 Suggested Answers
sleepy_user
  • 140 Answers
SOURCE: I am looking for a repair facility for Adcom pre
Here are all the repair facilities listed with Adcom for Califorina.
Hope this helps.
Accutech
16617 S. Normandie Ave, Ste. C
Gardena, CA 90247
United States
310-324-7406
Classic Audio Repair
3401-F Adams Ave.
San Diego, CA 92116
United States
619-282-9101
classicaudiorepair@gmail.com
http://www.repairaudio.com
E. Joseph (walk-in only)
3969 S. Sepulveda Blvd.
Culver City, CA 90230
United States
310-390-1077
George Meyer TV & Stereo
12418 Santa Monica Blvd.
Los Angeles, CA 90025
United States
310-820-1113
georgemeyer00@aol.com
http://www.georgemeyer-av.com
Northridge Electronics
4505-2B Industrial Street
Simi Valley, CA 93063
United States
805-583-1919
HADRIAN333@YAHOO.COM
Scan Audio Service
8101 Orion Ave, #5
Van Nuys, CA 91406
United States
818-786-4240
scanaudio@sbcglobal.net
Solutions! Speaker Repair of California
4334 Sunset Blvd.
Los Angeles, CA 90029
United States
323-666-4161
TV Unlimited
1296 Kifer Road, #601
Sunnyvale, CA 94086
United States
(408) 733-6913
kdpark@sbcglobal.net
Posted on Feb 20, 2009
  • 57 Answers
SOURCE: Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Posted on Jul 06, 2009
caroldon
  • 17130 Answers
SOURCE: Re: Technics HD51 home stereo system (amp, tuner,
The Amplifier must have a high impedance input for the turntable to be connected. Now most of the present day amplifiers do not have this input but only the regular aux input which is designed for a larger signal . But the turntable outputs is quite low and so it requires an amplification of high order. What you can do if you need to play the turntable is to have first a preamplifier with a high impedance which is available even inkit form and can be fitted on to your system. The preamp output can be shared into the input of the source selector maybe with a switch and you willl be able to fix two RCA sockets to accept the input of the phono. This will work fine provided the shielding is done well to avoid the high feedbacck to oascillate and cause noise, the premap must be housed in a shielded cabin. On the other hand you may have to buy a universal amplifier so that the phono input is present. Definetely nothing better than a designed input. So think and decide. hope I could help; Good day
Posted on Aug 10, 2010
How do I eliminate buzz?
Things to check:
1. With your multi meter, measure from left ground to right ground. What do you get? Measure from each input ground to chassis. What do you get there.
2. Get or make a pair of shorting plugs. Plug those into the inputs. Power on. Hum there or gone?
3. Turn the pre-amp on. Connect. Level of hum change with preamp on?
4 additional information. How efficient are your speakers? This is a big amp, high-efficiency speakers may show some noise, while low-efficiency speakers won't.
A trip back to the shop may be indicated, too.
Nov 23, 2015 | Adcom GFA-5500 2-Channel Amplifier
Hook-up my Nikko gamma FM 5 tuner TO NIKKO PRE-AMP BETA 2
Maybe I don't see the issue. The output of the tuner goes into the preamp jacks marked tuner. If I'm missing something, please let me know.
Dec 30, 2014 | Audio Players & Recorders
Whent turn up the valume sound whit no power
I would contact Adcom for a service place near you
Feb 17, 2010 | Adcom GFA-5400 2-Channel Amplifier
FM tuner does not play
Hard to say without knowing more, but many tuners have a squelch function that "mutes" the output unless the signal level reaches a certain threshold. You might want to look at the control panel and search for such a switch and de-activate it.
You didnt say if this was connected to an external pre-amp or a power amp. If so, the issue could be simply one of the correct cabling and selector switch setting
Sep 21, 2009 | Yamaha RX-770
Cant figure how to hook my stereo up
what to remember is pre-amp is before the amplifier then the amplifier to the speakers, go this route, Tuner for radio? from the radio tuner out go to the pre-amp tuner input, then from the pre-amp OUT go to the AMPLIFIER IN, tuner, cd, dvd, tv, any source, if you are using a 2 channel amp and pre-amp this is relatively easy, a little more detailed for multi-channel pre-amps and amps but follow the same path, sound source signal ie. tuner to pre-amp, pre-amp out to amplifier and speaker hookup to amp channels,
Jan 29, 2009 | Audio Players & Recorders
Just buy an amp
Yes, -- the GFA555ll is a power amp that needs a pre-amp for control. A good recommendation would be GTP500 pre-amp
May 29, 2008 | Audio Players & Recorders
Instruction manual
Trying to use the computer controlled JVC AM/FM Tuner Model FX-333.
I am attempting to use the pre-set stations desired for listening pleasure, but I have not been successful. Can you help me?
The FX-333 Tuner is linked to the AX-R441 Amp.
May 22, 2008 | Audio Players & Recorders
Equilizer
I need more information to help you. The equalizer has to go in between two devices to have an effect.
Like this:
  • Multiple units' (CD Player, Tuner, Cassette, etc.) OUTPUTS to Pre-amplifier INPUTs
  • Pre-Amp OUTPUT to Equalizer INPUT
  • Equalizer OUTPUT to Amplifier INPUT
If you don't have a separate Pre-Amp, you have to try something else. Re-post if this is the case...
Dec 25, 2007 | Spectrum Technical Hifi EQ-B5100...
53 people viewed this question
Top Parasound Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Gil Shultz
Are you a Parasound Audio Player and Recorder Expert? Answer questions, earn points and help others
