Question about WYSE Winterm Computers & Internet
Touch screen calibration is opposite
Touchscren on wyse thin client is calibrating opposite of touch points.
SOURCE: Hardware reset Wyse S30
Password should be Fireport, note the capital F.
Posted on Jul 06, 2007
SOURCE: Wyse S30 thin Client with Ubuntu
I played with those a lot with the LTSP and finally made it work...
All in all, the problem is that the X.org cannot autoconfigure the graphic chip of this client. On ubuntu 7.10 you need to force it to use the amd driver and cannot do it from the LTSP.conf file.
In your LTSP.conf file, you have to point to a xorg.conf file specific for your s30 thin client (I called it s30xorg.conf). Then you need to build this xorg.conf file (lots of help on the net on how to do this) and place it in the right folder. (The folder is probably not the same than on my system but it should be pretty obvious or at least written in the manuals or help files where to pu it). In this xorg.conf file, you will need to specify the amd driver and some standard vesa resolutions and refresh rates (also widely availavble on the net). Then dont forget to rebuild your LTSP image with those new files in the tree.
If I remember correctly you will also need to disable the ubuntu splash screen from another config file somewhere... I am sure you will find which one.
Then voila.
Let me know if you can make it work... if what I said is total gebrish, go on reading everythin you can find on the net until you understand what is here.
Thanks
Posted on Dec 04, 2008
SOURCE: black boxes
In the "experience" tab, uncheck the "bitmap caching" box and the problem will disappear. This is checked by default, but causes the black boxes in most situations unless you uncheck it.
Posted on Mar 03, 2009
SOURCE: How do I enable print screen botton
Depending on what keyboard you use, you may have to press the "F" toggle key to enable print screen.
  • 25 Answers
SOURCE: wyse 1200LE - error - out of frequency
This is caused by the terminals default display resolution (or the resolution that it was set to in its previous environment). The easiest way to get a display, would be to use a different monitor with a higher range of supported resolutions.
Fingers crossed the previous wnos.ini file would allow a G-key reset. If so, just hold down the G key when the terminal is booting, and it will reset to factory defaults. This might allow your monitor to work. (I think the default resolution is 800x600)
The problem you have is that the terminal might be locked down via the .ini file. So changing the configuration might be difficult. You could use a program like Wireshark to perform a network trace, this would tell you where the terminal is looking for it its wnos.ini file.
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration.
Posted on Jul 07, 2009
My wyse laptop turns on but my screen stays black
try undo things..if problem solved then,try use different cards
May 17, 2012 | WYSE Winterm V90LE Thin Client - Thin...
I have a wyse winterm v30 thin client. what steps will it take in order to reload the firmware?
you can download this pdf guide from
https://support.wyse.com/OA_HTML/cskmbasicsrch.jsp?jttst0=6_23871%2C23871%2C-1%2C0%2C&jtfm0=&etfm1=&jfn=ZG455B66622DEA31A7AE70467E3EBEC537FE9176B1484EFD6E483B952B0ED1CF6F10611204C7B33B20AA233809D7249C41FE&oas=etuN3Cl3pQgYaOxTZDlD7w..&categoryId=10820
this will show you the steps to do a USB firmware upgrade.
Mar 20, 2011 | WYSE Winterm V30 Thin Client - Thin Client...
Its saying calibration problem on the screen
When the Reader device is started for the first time or is reset back to factory settings, the screen must be calibrated. The Reader device will display a calibration screen that requires you to touch the stylus to the center of an "X" at several points on the screen. This is to make sure the touch screen properly recognizes input.
The process requires you to touch the "X" in the following locations on the screen:
  • Top left
  • Bottom right
  • Top right
  • Center
If the screen is accidentally touched someplace other than the center of the "X" during calibration, the Reader device will display a message stating Calibration error detected. Please restart calibration process .
If this happens, please start again in the top left corner and touch the stylus to the center of each "X" as it is displayed, being careful not to touch any other part of the screen. After the sequence is completed the Reader device will display Touch Panel calibration completed . Click OK to continue to the next step in the setup process.
Dec 26, 2010 | Sony Reader Touch PRS-600
Calibrating touch screen
calibrating touch screenProblem with Pioneer AVH-P5750DVD Car DVD Player
May 20, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Calibration wizard.you have to calibrate the touch screen
calibration wizard. you have to calibrate the touch-screen mobile model No: JC 777s
Jun 13, 2009 | Handmark Software MobileLists (950142) for...
Black boxes
Feb 25, 2009 | WYSE V90 Network Terminal
The touch screen and the pen do not pair to function
my i9 phone does not apply the touch screen anymore and the pen calibration i cant click on screen . when i try to calibrate it keeps on the same infomation of "touch where the point is , left, center and right.
Dec 24, 2008 | Dual Electronics CECT P168 Cellular Phone
TyTn II unresponsive touchscreen
Try to calibrate the touch screen. Also clean it with a soft cloth. But calibrating it should help the film when you tap the screen.
Apr 16, 2008 | HTC TyTN Smartphone
Calibration of my MobilePro off
We've put together some useful tips on calibrating your MobilePro * When calibrating your touch screen be sure to use the same amount of pressure that you apply during normal use. In general, the lighter the better. This allows the screen to recognize taps consistently. * When calibrating your touch screen hold the stylus over the calibration point until it moves to the next point. Holding it for this period will lead to greater accuracy than just tapping the spot quickly. * When calibrating your touch screen support the screen from the back with your other hand. Try not to grasp the screen from the side with your thumb on the front. * When calibrating your touch screen do not let anything other that the stylus accidentally touch the screen. For example, don't rest part of your hand on the screen to help steady the stylus. * Once you've completed the stylus calibration, be sure to perform the double tap calibration as well. This will ensure greater accuracy.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Computers & Internet Logo
94 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Tim Hunt
Tim Hunt
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
