Question about Sharp LC42SB45U 42 in. LCD TV
Cannot change input from t.v. or remote - Sharp LC42SB45U 42 in. LCD TV
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
Magnavox input change
If the remote is its original one, there should be a button marked 'TV/AV'. Press this button to select inputs.
Jun 21, 2013 | Magnavox Televison & Video
Insignia ns27rtv can not change input without remote
As there is no menu button on the front of the TV, you must have its remote control to select he inputs.
Jan 11, 2013 | Insignia Used Original NS27RTV Remote...
I have lost the orignal remote for my tv and have a universal remote. I get the tv/video button to work. is there some way to change it with out using the remote?
Unfortunately, the Input button (to change the source from INPUT 1, INPUT 2,
INPUT 3, INPUT 4, Front Input, HDMI/DVI, and last-active channel) is only on the remote. If your universal remote was built 6 months after the TV was released, try a different code for RCA/Thomson TVs (assuming the remote has an input or source key). Thomson built the TV.
If your universal remote doesn't have an input key, you probably need a higher end remote (one with that key or one that can be programmed from a computer). Alternatively, you can get an exact replacement remote here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=HD52W58&uuid=12927154203570 .
I hope this helps.
Dec 18, 2010 | RCA HD52W58 52" TV
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Can I change input mode manually?
Try channel button to 1-2-3--99-98-1-2-3 up & down it should come between 0 & 1
Jan 21, 2010 | Sylvania SRT2232S 32" TV
I have a Toshiba 24af42 with no remote. I am trying to change the input, but without a remote I cannot figure out how to change it. I have tried a universal remote which works for other functions, but not...
Try this website 1-800-remotes Factory original u can buy an original remote,tries Channels up or down couple times u should get in the input 1 or 2.
Oct 22, 2009 | Toshiba 24AF42 24" TV
Need to change input mode to video
on your remote there is a input button if you
have the factory remote.press this and will
change inputs.
Jul 18, 2009 | Televison & Video
How does one change the video inputs without the remote control?
If you have lost the remote, go to any electronics store and buy a universal one. I have programmed many generic remote controls, and they all work fine for adjusting the video inputs. Not all television sets allow their video inputs to be switched without the remote. Most likely you will have to buy a replacement.
Jan 08, 2009 | RCA Scenium L50000 Television
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
Sharp LC42SB45U 42 in. LCD TV Logo
29 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
