Question about Dell 1409X DLP Projector
Why is the orange lamp and heat light on when I turn on the projector?
SOURCE: Dell 2300MP Projector Lamp - "Orange Light"
Have you put the lamp cover back on? as I did the same and it would not power the lamp.
Posted on Nov 19, 2008
  • 38 Answers
SOURCE: Dell 1100MP Projector, unit stopped working, I
This is a very common problem with these projectors. The fans lock up and the units are out of warrenty. The fan you replace it with must be the exact same as the old one, even though it is the same as a 5$ computer fan. The processor will detect the non-dell fan and shutdown in the same way.I Havent been able to find any replacement fans that will work. I may be interested in buying your broken projector from you if you give up.
Email me at: nalexandrov251[A-T]gmail.com and we might be abe to work something out.
Posted on Dec 08, 2009
  • 146 Answers
SOURCE: Dell 1800mp projector will not power up and an
have you checked fans??
make sure they are running and filters are clean and not blocked
also did you try to unplug projector for at least 5 minutes and try repowering to check
also make sure you are properly connected to a source that is hooked up and working - sometimes if you have no video to an input projector will not turn on
hope this helps
good luck!!
Posted on Mar 28, 2011
SOURCE: Dell Projector 1800MP Lamp light/Power bottom
Send it to MooreDesigns. He fixes for $40 plus shipping.. Just had mine done. Quick response, good communication.. Saved me a lot of money
Posted on Apr 23, 2011
ynogami21
  • 670 Answers
SOURCE: Dell 2400mp projector turns on
hi there,
A blinking orange light indicates that a projector fan has failed and the projector automatically shuts down.
To get this problem fixed you would have to open the projector check which fan has failed and have it replaced.
Otherwise, if its still under warranty you may want to contact DELL tech support.
Hope this helps!
Posted on Jun 14, 2011
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Power light orange color Near it a key symbol - orange color Projector lamp not glowing
hi,
If the lamp light is solid orange then, the lamp of your projector is faulty. You have to repalce the lamp.
ok
Aug 01, 2011 | Dell 1409X DLP Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Dell 1800mp projectors turns on for a few seconds then turns off and lamp light stays solid orange...what's the problem. New bulb?
Hello
If the Lamp light and power lights are blinking orange, the lamp driver has failed, and the projector will automatically shut down. Unplug the power cord from AC mains wall socket, wait for three minutes and replug and see whether it helos you. If not, contact Dell service center.
OK.
Nov 19, 2010 | Dell 1800MP Projector
The projector doesn't turn on.power,temp,lamp orange light are on
overheated. clean it out with canned air. try again. if it still has an issue, you may have a main board problem.
Oct 19, 2009 | BenQ MP511 Projector
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
The tv shuts down and an orange light flashes
if it's the lamp led that is orange, turn off the projector for a minute and try it again. if the lamp goes out and the orange led comes on again, replace the lamp and reset the lamp timer.
Jul 25, 2009 | InFocus X10 DLP Front Projector 1080p DLP...
Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Feb 25, 2009 | Panasonic PT-LB10SVU Multimedia Projector
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
I've heard it could be the ballast, check with Dell for replacements
-- Deft
Aug 21, 2008 | Dell 3200MP Multimedia Projector
Dell 1409X DLP Projector Logo
63 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
