Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
I HAVE A GU3200XTP AND LIGHT BLINKS 7 TIMES AND IT WILL NOT START AND CLEAN WHY
the dr
  • 447 Answers
SOURCE: whirlpool gu2400 clean light is blinking 7 times
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
Posted on Dec 23, 2007
SOURCE: light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Posted on Aug 31, 2008
SOURCE: not working
Solution #3 is good, but you need to hit "High Temp Wash" and then "Heated Dry" back and forth 3x to reset the computer.
Posted on Oct 13, 2008
  • 111 Answers
SOURCE: Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Posted on Jun 20, 2009
rylee_smith
  • 8619 Answers
SOURCE: My dishwasher clean light is blinking 7 times & not clean
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 22, 2009
Clean light blinking will not start
Count how many times it blinks before it pauses and repeats. If it's 7 times, then it is a very common problem, and you can find the solution by searching for "dishwaser clean light blinking 7 times".
Nov 03, 2014 | Kenmore Dishwashers
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
My Whirlpool GU2400XTP83 stopped during the wash cycle and there is a blinking light above the "light" cycle button. I can not reset the dishwasher, stop or start it.
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times ina row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
The clean light blinks 7 times
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jan 02, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
My ready light blinks 7 times and my dishwasher will not run
reset the computer by pressing heat dry normal heat dry normal
Jul 02, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
DU1055XPTQ0 DISHWASHER STUCK ON "CLEAN" BLINKS 7 TIMES, REPLACED HEATING ELEMENT ANYONE KNOW CODE TO RESET?
I believe its pressing heated dry, normal, heated dry, normal keys withing 6 seconds. There should be a tech sheet attached to the toe panel at the bottom front of the machine.
Feb 17, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Nov 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Doesn' cycle power is on except drain cycle goes, clean light blinks 7 times
Check this link for more info:
http://www.repairclinic.com/0088_9_1.asp
Jun 17, 2008 | Dishwashers
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
197 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
