Question about Briggs & Stratton Garden
Torque specs rocker arms - Briggs & Stratton Garden
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
Rocker arm torque is 100 inch pounds.
Posted on Feb 07, 2016
3 Suggested Answers
  • 3911 Answers
SOURCE: i need to adjust rocker arm clearance on a 15.5 briggs engine
you go to the briggs & stratton website, already knowing the numbers from the side of the engine, you look the clearances up under support.
you go to you tube and search, i am sure there will be some videos on there for adjusting rocker arm clearance. one short movie is worth a thousand words. the key is to understand the timing. where the piston is in relationship to where the valve should be. once you have them adjusted, make sure you turn the engine over a few times without the plugs in, and then do it again.
Posted on Apr 05, 2010
BAMOUT
  • 2478 Answers
SOURCE: farmall a rocker arm torque
12-15 FT. LBS
Posted on Dec 07, 2011
Torque specs 2003 olds silhouette rocker arm 3.400
Here is a suggested updated torque spec for this engine's rocker arm bolts;
Rocker arms
Step one: Torque to 11 ft lbs then tighten an additional 90 degrees of bolt head rotation. Some guys don't fuss with the torque specs and just get them good and tight. Either way, be careful, as the heads are aluminum. You do not want to over tighten these bolts
Oct 07, 2016 | 2003 Oldsmobile Silhouette
What are the rocker arm torque specs on a 1996 dodge caravan 3.0 liter
Hi Derrel,here's a link to a Autozone repair guide on your rocker arms,you can join their site like me for free and use all their repairs guides,need more help,let me know,k. Repair Guides Engine Mechanical Rocker Arm shafts AutoZone com
Aug 29, 2016 | 1996 Dodge Caravan
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
Rocker arm pivot torque for olds cutlass 1987 307
Oldsmobile Torque Specs - GbodyOlds.com
www.gbodyolds.com/forum/showthread.php?754-Oldsmobile-Torque...
Feb 7, 2013 - 2 posts - ‎2 authors Oldsmobile Small-Block Engines Cylinder Head Bolts (1/2in. bolt) 130 ft. lbs. Cylinder Head ... Rocker Arm Pivot Bolt 25 ft. lbs. Rod Bearing ...
Rocker Arms - AutoZone
www.autozone.com/...Cutlass...1987.../Rocker-Arms/_/P-0900...
AutoZoneGM Cutlass RWD 1970-1987 Repair Guide ... To remove the rocker arms from the shaft, the nylon arm retainers must be removed. ... 7: Engine valve system, 260, 307, 350, 403 Oldsmobile built engines ... Unfasten the two bolts that attach the rocker arm pivot to the cylinder head. ... Torque the retaining bolts to 25 ft. lbs.
Dec 01, 2015 | 1987 Oldsmobile Cutlass Salon
Torque specs 2003 kia sedonna rocker arm
Tighten the bearing cap in two or three steps. Tighten it to the standard torque at the last stage. *Bearing cap standard torque Torque16 pieces at the both ends : 18.6 - 20.6 N·m(190 - 210kg·cm, 13.7 - 15.2 lb·ft)24
Jun 16, 2014 | 2003 Kia Sedona
Rocker arm torque specs on a 2001 chevy malibu 3.1
Rocker arm torque specs for the bolts are 14 Nm (124 inch lbs.)
Apr 15, 2011 | 2001 Chevrolet Malibu
2004 pontiac grand am 3.4 rocker arm torque?
the rocker arm torque specs for the la1 gm 3400 sfi v6 is 168in lbs or 14ft lbs and 30degrees past that hope that helps you it came straight from my local dealer!
Apr 05, 2009 | 2004 Pontiac Grand Am
Intake and rocker arm torque specs. thanks
on 3.1 v6 it is--rocker arm bolts--- 89 in-lbs,intake manifold(lower)---step 1-62 in-lbs step 2 115 in-lbs. for year 1997 3.1,
Dec 26, 2008 | 1997 Chevrolet Malibu
Garden Logo
66 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
