Question about Sony Xplod XM-554ZR Car Audio Amplifier
I removed the faceplate now nothing works - Sony Xplod XM-554ZR Car Audio Amplifier
After removing faceplate on hallway controller two wires crossed and sparked after replacing faceplate nothing worked. checked breaker outside and nothing has been tripped now what
Double check your breakers, shut them all the way off, then back on. Sometimes when they trip they don't move much and they can be easially missed. Resetting all of them will let you know if it really isn't a breaker. If it isn't, it sounds like you may have broken or fried a wire somewhere. This can be very dangerous. I recommend calling an electrician to troubleshoot asap.
Sep 16, 2013 | Heating & Cooling
Xbox wont turn on
Your console should turn on when the eject button is pressed. Press the eject button on the front of your console.
If the console turns on when you press the eject button but not when you press the power button, the console faceplate might not be attached properly. To make sure that the faceplate is attached correctly, you should remove it and reattach it.
  • Position your console horizontally, as you would position a DVD player.
  • Unplug the power cord and any other cables connected to the back of your console.
  • While holding your console firmly, curl your fingers inside the oval USB door on the front of the console.
  • Push the faceplate away from the console with your thumb until the faceplate comes off.
Note You will need to use some force to remove the faceplate.
Once the faceplate is removed, look at the tabs on the back. If any of the tabs shown in red in the illustration below are broken, order a replacement faceplate by contacting Xbox Support.
If none of the tabs are broken, re-attach your faceplate by pressing it firmly until it clicks into place.Try to turn on your console again. If removing and reattaching the faceplate did not solve the problem contact the xbox support.
Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
Garmin Nuvi won't turn on
See if you can find the reset button on the unit and push it while the unit is on. On newer units the reset button is on the back, but on older units it may have a faceplate cover around the edge of the screen you have to remove and the reset button is sometimes located under the faceplate...this may work
Jan 01, 2009 | Garmin Nuvi 660 GPS Receiver
Pioneer deq 7600 display went black today the eq works fine.
the faceplate contacts may need to be cleaned. remove the faceplate, and using an eraser, clean the metal tabs on the main unit and rear of the faceplate.
If this doesnt remedy the problem, service is required. May be the light unit in the faceplate.
Dec 22, 2008 | Car Audio & Video
Faceplate not working
is any sound coming out to the speakers
Jun 30, 2008 | Kenwood KDC-MP4028 CD Player
Power on, but just show logo, then turn off immidiately.nothing change after I remove faceplate and reset
Have either of you tried charging this via the USB connection on your computer? Sometimes this helps. Give it a try.
Jan 20, 2008 | Garmin StreetPilot C330 GPS Receiver
Functions do not work even after resetting.
try cleaning the faceplate pins on the faceplate and the deck with alchool and q-tips, that dont work id start with peanuts :-)
Don
Nov 27, 2006 | Sony CDX-R3000 CD Player
Sony Xplod XM-554ZR Car Audio Amplifier Logo
35 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
