Question about Garden
Does anyone have access to a karcher hds 580 pressure washer I need a picture of the terminal board where all the wires connect
I need to locate the connections for the fuel pump solinoid, the ignitor, and trace the 24 volt dc coming from the control transformer.If i could locate a wiring diagram that would be excellent. It is a 1985 karcher hds 580 /ER691 1.608-121 115 v
  • 883 Answers
SOURCE: Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Posted on Jun 10, 2007
SOURCE: karcher HDS 750 HOT HIGH PRESSURE WASHER
G-day Mate.
Did you check if the igniters? they may be cloged up with ****. Unscrew the Sight glass on top of the boiler and run the machine (in cold or hot mode, doesn't matter, as the igniters are running all the time) and see if there are working, you should take them out anyway and give them a wipe with a rag as general maintenance item, and when you put them back in there should be about 5mm gap between them.
Less common reasons for the boiler to not work
- Faulty fuel solenoid valve, (You should hear a click sound about 5 - 10 seconds after you pull the trigger)
- Dirty fuel filter,
Take a look at those simple things and let me know if its any of these.
I have a Karcher HDS 750 1989 Year model
This machine just keeps going, it's had a fairly tough life but it has stood up to it all,
i hadent spent anything on it until about 6 months ago when i purchased a new fuel pump for it as the old was wasn't pushing 170PSI to the Disiel injector it had slowly droped 70psi, and it doesn't create a hotter burn in the boiler, but still very good for a 19yr old pump,
other than that thats all it's needed, it's still going strong to date
Very robust machine.
my e-mail is cgodfx@internode.on.net
Cheers Matt.
Posted on Nov 07, 2008
  • 11 Answers
SOURCE: No water to my Aprilair model 550.
Some sump pump have a safty switch that will not let the hum. come on if the tank is full of water, I,m not sure if this is the type that you have but make sure that the pump is pumping water. Also your humidistat have an internal switch that it should be set to bypass not to power Note: some humidifier have their own power supply the 550 dose not
Posted on Feb 09, 2009
  • 2692 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
iadame
  • 676 Answers
SOURCE: Fuel pump not activating and delivering fuel to carb, 1985 Nissan
Check in the fuse block to check for the fuel pump relay.
Posted on May 05, 2009
Karcher hds 558c after about 15mins looses pressure, then about 30 seconds later pure stream come out
Sounds like water is not getting to the pump for some reason. As the pump needs constant water flowing through it for cooling, you should not operate the unit until you find the problem. The pump could be damaged.
Jul 18, 2016 | Karcher Garden
Karcher HDS 7/10-4M has the oil light giving 4 flashes, what does this indicate as the fault.
Ive got a brand new HDS 10/20 and its crapped out on me already, water line filters were blocked, cleaned them out and now it splutters after 2mins of pressure washing, oil light flashing x3, nothing in any of their **** manuals to assist, any ideas before i set it on fire?
Jan 19, 2013 | Karcher Garden
Whare can i get a pump head for a karcher hds 1000 de
I work for one of the top Karcher dealers in the US and we can get this part for you. Visit our website at www.landanw.com for contact info or call 800.247.8103.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Feb 26, 2011 | Karcher 2500 PSI Pressure Washer
I am looking for a workshop manual for karcher hds 555 ci hot pressure washer.or access to where i can download one. any assistance is greatly appreciated
hi could you post your email address and i can email you a full pdf file, also on the chassis of the machine there will be a silver sticker could do with all the numbers to find which modle it is regards
Jan 19, 2010 | Karcher PSI Electric Pressure Washer
Need to reset and adjust downloader.
Hello sir, please if you know how can reset service intrval for KARCHER HDS 10/20M year 2009.Thank you .
Apr 09, 2009 | Garden
Hi,karcher hds hot pressure washer now pressure when you pull trigger and pulses.
what you need to do is, take the screw fitting which goes to the water tank off, then the one that goes from the water tank to the pump head .
then put the one that was in the first place going to the water tank on to the pump and force feed with water.
see if you can see water leaking from any where seals hose.
try running the machine to check the pressure.
if water leaking from pump head you need seals.
Mar 21, 2009 | Karcher Garden
KARCHER HDS 1000 de
Hi Jim,i have the same unit to,can you tell me are you connecting to mains water via the small black header tank at the back next to the boiler or is it connected straight to the pump head inlet?
Theres more than one reason i'll just start with this one 1st.
chris
Aug 08, 2008 | Karcher 2500 PSI Pressure Washer
Karcher HDS 750 HOT HIGH PRESSURE WASHER
G-day Mate.
Cheers Matt.
Apr 07, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
