SOURCE: leaking sub zero 650
I fixed my leaking problem by pulling out the vegetable drawer and checking the condensation drain hose. Sure enough, it was clogged and the condensation had nowhere to go but move out toward the front of the fridge, down the left side and onto the floor. Once that drain hose was cleared (with a bendable straw), no more leak!
SOURCE: sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
SOURCE: I nee to tighten up the freezer door handle on a
There are different handles depending on serial number. The older of the two is at the top of the door. The screws are covered with a magnetic trim piece. You can remove this by putting tape on the chrome and pull up. You can then tighten the nuber two phillips head screws. The newer model is on the door itself. These are held on with small set screws accessed from the bottom of the handle. You may get by just tightening the set screws. If not you need to remove the handle by removing the set screws. You can then tighten the standoff and reatach the handle. For the 632 same procedure except it will be on the side.
SOURCE: vacuum condenser light of sub zero 650 is on - how to clean it
We recommend vacuuming your condenser every 3 - 6 months. Cleaning the condenser is important for the overall operations of the unit including cooling functions. A dirty condenser may lead to warm temperatures in the refrigerator and freezer. It may also cause the unit to run excessively. It may contribute to condensation or frost inside of the compartments. If the condenser is not cleaned properly it may even cause premature failure of mechanical components in the unit. Condenser Cleaning - All Models Before cleaning the unit, shut the electricity off at the control panel. When you clean the condenser, wear gloves to avoid injury from the sharp condenser fins. Use a soft bristle brush and vacuum to remove dust and lint from the condenser. To avoid bending the condenser fins, be sure to vacuum in the direction of the fins, up and down. Clean the condenser every three to six months or sooner if you have pets. 600 Series Framed and Stainless Steel louvered grilles: First remove the grille screws located at the bottom of the grille. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. Overlay Panel Grille: To remove, lift up then pull out at the bottom and down to release from its mounting bracket. Remove the two black screws in the lowest louver of the grille. Tilt the bottom of the grille out and away. It will release from the top of the grille. Model 601RG Stainless Steel Grille: Remove in a similar fashion as the overlay grille panel. 700 Series All Units: At the bottom of the unit, remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 400 Series 424/424FS At the bottom of the unit, remove the screws holding the kick plate. The condenser is located behind. 427/427R: Remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 430: First remove the screws located at the bottom of the grille. NOTE: These screws (Phillips head) are accessed with the door open. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. 200 Series 245, 249, 315W Remove the kick plate at the bottom of the unit, giving you access to the condenser area.
