Incompatible fuser module - Office Equipment & Supplies
I have a problem of fuser module (r3) temperature error in xerox workcentre 5755
Can you feel any physical heat from the fuser. Sounds like either the thermistor that controls temperature or the lamp failed.
Sep 15, 2016 | Xerox Office Equipment & Supplies
Hp photosmart c5380 all in one
did you hust replace the fuser? make sure it is the model type/ for example a 4200 does not work in a 4250 they fit and look exactly alike,but, are not compatible.
Mar 27, 2014 | HEWLETT-PACKARD Office Equipment &...
Repeatedly long beeps
If you upreage the RAM to 2Gb by inserting a 2nd 1Gb memory module then the 2nd RAM maybe faulty or incompatible.
If you insert a 2gb memory module to replace the 1Gb memory module then it maybe faulty or incompatible.
Try using the same make and RAM speed as the original RAM module.
Dec 29, 2012 | Biostar G31-M7 TE Motherboard
What wud be the reason behind fuser error in a printer?
A fuser is basically a really hot light bulb or heater element, turned on and off by the AC power module.
If the bulb/element blew, or the AC power module is stuck on or off, the temperature won't get hot enough, or will get too hot.
Either too hot or not hot enough will cause a fuser error.
Sep 08, 2010 | HP Office Equipment & Supplies
FUSER GETTING OVER HEATED IN XEROX PHASER 7400.SOMETIMES A4 PAPER GETTING JAMMED IN FUSER ,WITH A3 PAPER THERE IS NO PAPER JAMMING PROBLEM.
try to clean paper feeding rollers and chek fuser paper sensor, maybe paper comming too late...chek this just to be sure all its OK whit paper path and fuser.
...or replace fuser module!
Aug 23, 2010 | Xerox Phaser 7400DN Laser Printer
Ink on centre of the page is blurred and coming off
Assuming you haven't just changed one or all of the toner cartridges (if you have one or all of them could have the wrong toner, which is incompatible with the printer).
If the toner is not fusing to the paper, then this is most likely to be a fuser problem.
Its a bit curious that onle the toner in the centre of the page is loose, but this can happen if there has been a paper jam and there is a piece of paper wrapped round the fuser. Can also happen if non laser compatible labels have been printed, and some have come off the backing sheet and 'dissapeared' into the prnter.
The fuser in thhis printer is really easy to get to and remove. Open the front door and there is is at the top front of the printer.
MAKE SURE THE PRINTER HAS BEEN SWITCHED OFF FOR A WHILE TO ALLOW THE FUSER TO COOL - THEY GET VERY HOT IN NORMAL USE AND YOU CAN BURN YOUR FINGERS HANDLING A HOT FUSER !!!
Apr 20, 2010 | Dell 3110cn Laser Printer
I added more memory to my vista
Has the BIOS detected the additional memory or it has stayed the same?
Is the new RAM the same make as the other RAM module and speed?
To determine if the new RAM is OK, remove both RAM modules and insert only the new RAM module and see if the laptop boots up.
If it doesn't boot up then the RAM module is either faulty or incompatible with your laptop.
If it boots up then insert the other RAM module in the second memory slot. Check the BIOS to see if the RAM has increased. If not then the RAM modules are incompatible with each other. I suggest you look at the make of the original RAM module and purchase the second one from the same manufacturer.
Aug 26, 2009 | Dell Computers & Internet
Over heat messege
Chances are that you are looking for your printer FUSER, not a fuse. The fuser is the rolling element that bonds (via heat) the plastic charged toner particles to your paper. It is located in the rear of the printer. Unplug, remove four screws that secure the back of the printer. Once removed, you will see a circuit board and the fuser. The fuser has two sets of wires (one on each side) that should be unplugged with your hands. Remove the four screws that keep the fuser module in place and replace that module (call Dell parts for replacement).
Mar 10, 2008 | Dell 1600n All-In-One Laser Printer
Xerox printing problem
Is it asking for the fuser module to be replaced? The fusers have a fuse or a chip in them that turns them off after a certain number of impressions.
Jan 12, 2008 | Computers & Internet
jasbo
jasbo
