Had tv since nov 08 dont have code for working volume or changing channel with my sky plus
  • 258 Answers
You should be able to find a list of codes in your universal remote manual, usually at the back, there will be codes for all different brands of tv's/dvds/videos etc, get the code out of the manual that suits the brand of tv you are using, if no codes there have a look in your tv manual for the signal code
Posted on Jun 23, 2009
I would like to find out the TV code for my 55' Bush tv so I can programme my sky TV remote please.
Hi Darren, I have Sky (foxtel) and the Sky box (foxtel box) is hooked up to my television and the only thing is i turn the volume up to full on the television and control everything (volume and change channel) through my Sky(foxtel)remote control..... I hope this helped, CHEERS..
Mar 31, 2016 | Bush Televison & Video
Code for Sky remote for AlbaALCD15DVD2 tv Thanks TH
Hello
Sky remote codes to check with Alba TV are:
037 065 246 399 263 064 446 609 275 077 515 244 398 239 400 459 191 383 607
696
705
742
471
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 to 3 and work through all the relevant 3 digit numbers from the Sky Plus remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Sep 20, 2011 | Televison & Video
How do I control my tv volume through my sky remote control
Set the Sky remote code for your TV first. Then you can change channels and volume.
Nov 18, 2010 | Televison & Video
Hi, what is the sky remote code for Toshiba TV model 32BV500B? Thanks.
I've found two codes that work fine on a revision 8 Sky remote control and a revision 8r remote:
0056 (LG/Goldstar)
981 (General reset)
Both codes enable volume, channel selection and power on/off.
Nov 11, 2010 | Toshiba Televison & Video
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Have Sky plus and the remote does not accept any codes I have got, so no volume control via Sky remote. Do you have the correct code for a Sharp Aquos 46" ? Thanks
please follow the steps below:
TV
RED + SELECT
TV
0093
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Jul 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Remote to opperate sky volume
TV
RED + SELECT
TV
0056
cheers
Little Dish Fitter
Apr 17, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
My sky remote only works part of tv
TV
RED + SELECT
TV
0056
Right you said in your post that it only works part of the tv, what this is when you have saved the code into the remote it is very close but not the correct code for the LG Model you have. So imput the code as mentioned above but when your checking the volume dont press SELECT straight away try the help button. power button etc then save that code if it works them. when it is the correct code you should be able to press the TV button then power = power . Help = changes av / source. Number button change channels etc. On certain tv's on a sky + or hd the pause/play changes the aspect ration on the tv aswell. When this sorts you out please leave a thumbs up cheers
Little Dish Fitter
Mar 20, 2009 | LG 37LG30 37 in. LCD HDTV
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Sky codes for beko 32' tv
on the sky remote press the following
TV
RED + SELECT (blinks twice)
TV
0125
press the volume button,if it works press SELECT if not press TV then VOLUME again repeat this process of TV then VOLUME until it works then press the SELECT button to save the code to your remote.
Enjoy
Littlle Dish Fitter
Dec 27, 2008 | Beko 324250WN 28" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
