Question about Dryers
How to replace a whirlpool calypso gvw9959klo pressure switch
My calypso GVW9959KQ2 displays L5
its probably LS not L5 code,which is a lid switch failure and this will result in a machine that will fill and possibly agitate,but wont spin out.replace lid safety switch located underneath top of units outer case
Aug 01, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Ld error code
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Water does not wet clothes on wash and even on soak.
Machine is not taking enough water in. Check the level control pressure switch. Could be set to too low a pressure
Jun 27, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine fills w/water quits flashes lb? lz?
There is a water pressure switch that operates when the required water fills in the tub. this pressure switch in your machine is possibly faulty. In ur case the water keeps filling then it detects an error and stops that's when the lights start flashing. the pressure switch fails to detect the amount of water in the drum and so the machine doesn't move on to the next cycle
Oct 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Fills with water, but won't agitate or drain.
I have a calypso that fulls with water but will not start it just fills with water and then I will get a FL coded.If it is the pressure switch were would it be? I do not see the part on the parts list.I removed the drain hose and removed most of the water.I have not checked the pump as of yet. the model # gvw9959kq0.please e-mail at rmrmoje@gmail.com with a fix.
Aug 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
MY WHIRLPOOL WASHER FLOODS YHE FLOOR ON FILLING BEFORE IT START T
you have a bad pressure switch or the hose come off in a unbalanced wash ,,, look in the top and check the hose (about a 1/4 clear hose) and make sure its still connected to the valve and if so replace the valve.
Larry
Nov 25, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso Washer
When changing a pressure switch on a calypso you have to be sure the tub is empty. blow air into the hose to clear, also observe for moisture where the hose connects to the tube for a pin hole leak in the tube.
Aug 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Dryers Logo
23 people viewed this question
Top Dryers Experts
