Question about Vehicle Parts & Accessories
Is there any fix for a slipping clutch pedal sector on a 1982 Toyota Starlet? New part is unavailable and used replacement slips at times.
    Master:
  • 560 Answers
Sounds like the flywheel needs resurfacing.
Posted on Sep 08, 2014
2 Suggested Answers
perkins48
  • 14337 Answers
SOURCE: 92 nissan 240 sx clutch is slipping
Your flywheel may need re surfacing or replaced.
Posted on Aug 11, 2012
What allows clutch to slip so much to not move car.
-Possibly time to replace new clutch.
Good luck
mai
Nov 10, 2014 | 1990 Toyota Camry
1992 gmc 5.7 350 nv3500 4wd standard transmission loses power while engine revs like my clutch is slipping, but no grinding gears and clutch pedal is fine. any ideas on what may be wrong
does sound like slipping clutch , you may not get all the symptoms at once , the slipping usually starts first then the hard gear change etc cant think what else it could be , may have oil contamination on clutch plate this would cause the slip , crank seal ? i think your going to have to drop the box and have a look keep me posted if you wish
May 15, 2014 | Cars & Trucks
Transmission slipping
This normally means your clutch is worn down and needs replacement. Much less likely is that the clutch pedal travel needs adjustment.
Replacement of the clutch requires removal of the gearbox and is much easier with a shop hoist. I'd recommend replacing the pressure plate assembly as well.
Jul 31, 2012 | 2003 Toyota Corolla
1994 toyota pickup clutch slips
If you have proper pedal free play (the clutch is releasing and engaging properly but slips when you apply throttle) then it's time for a new clutch. Worn out or has oil on it.
Oct 27, 2010 | 1994 Toyota Pickup
Peugeot 106 1.5D. the clutch was slipping so new clutch fitted 2 weeks ago. It was still slipping so that garage replaced the clutch again. Guess what? It is still slipping. Any idea what is going on?
Yes clutch pedal should start to drive about 1inch off the floor and when driving keep your foot away from the pedal,/ also when new clutch is fitted did they fit a complete clutch assy /and did they surface grind the flywheel as if it was badly worn on the 1st one then the new one wouldent last very long.
as when the clutch starts to drive 1" from the floor clutch is good /when it engages right out its buggered and slips so ask about the f/wheel
Oct 02, 2009 | 1991 Peugeot 405
No clutch
Yes this is evident in replacing engine oil to motorcycle engine.
Engine oil designed for automobiles isnt good for motorbikes as they offer additives for added "slipping". THis will cause your clutch to slip. Automobile Engine's oil system is separate from the clutch while motorcycle's clutch and engine fall under one oil system.
Use engine oil designed for motorcycles.
Solution: Buy and Engine flush, pour it to your crankshaft, run the engine for 5 minutes (idle) then drain. Replace with new motorcycle oil.
-levibit-
Jun 21, 2009 | 1982 Yamaha XJ 650
TRANSMISSON PROBLEMS
if its manual sounds like your clutch could be slipping does car smell of burt clutch?
check cluth adjustment
may need new clutch
do stall test with hand brake on, foot (heel-toe) on brake and accel pedal to about 2000rpm then let out clutch and car should stall if engine revs go down and engine still runs but you can rev causing slip and you will now smell what slipping burnt clutch is replace it.
if its auto check trans oil level and what does it look like red-good
darker red to black-bad often smells burnt also possibly new trans required.
May 31, 2009 | 2000 Toyota Celica
1991 Toyota pickup 4WD clutch slipping
There is an adjustment for the clutch pedal under the dash where the push rod goes thru the firewall. There is only aprx. 1/2" of adjustment so be careful when making an adjustment, if your clutch is slipping then you need to shorten the throw of the push rod.
May 06, 2009 | 1991 Toyota Pickup
Vehicle Parts & Accessories Logo
22 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
