Question about Sun Mountain Speed Cart V1
Trying to remove front wheel speed e cart flat tire
President club car golf cart front tires wear out every 3 months.
Maybe your front end alignment is off?
Measure the distance across the front of the front wheels and across the rear of the front wheels.
On this cart the measurements should be almost exactly the same.
Measure carefully as the measurement needs to be exact.
If the measurements are not the same,adjust one or both tierods to make the distance between the front and rear of the front wheels the same.
TIP:AVOID sharp turns on pavement which will also accelerate tire wear.
Apr 08, 2017 | Cars & Trucks
Where is the vehicle speed sensor located in a 1999 Buick century
Vehicle Speed Sensor Replacement
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information. Remove the right front tire and wheel. Refer to Tire and Wheel Removal and Installation in Tires and Wheels. Remove the right engine splash shield. Refer to Engine Splash Shield Replacement in Body Front End.
Remove the vehicle speed sensor wiring harness connector.
Remove the vehicle speed sensor bolt (9). Remove the vehicle speed sensor (10) from the extension case.
Remove the O-ring (11) from the vehicle speed sensor (10).
Vehicle Speed Sensor (VSS)
Lower right side of the engine compartment, on the transaxle
Sep 05, 2015 | Buick Cars & Trucks
How to fix abs on front brake for 2010 road king?
If you got any magnetism near the left side wheel bearing you will have destroyed its sensing/signalling ability. The magnetic pickup should only go back on one way in one position but check that it is located near the sensing wheel bearing. When it goes on it should be rotated up If the wheel somehow got mixed up and on backwards the magnetic bearing would be on the wrong side, away from the pickup. Check your wiring for damage.
Never pull the wheel speed sensor cable taut or use it to support any other parts.
Install the wheel speed sensor with the index pin on the out-board side or the sensor will be damaged. After the axle is installed rotate the front wheel speed sensor until the index pin makes contact with the shoulder on the fork slider and then route the wheel speed sensor cable up to the lower fork bracket along with the brake hose.
If installing a new sensor on a Road King and other Fork mounted fairing models turn the front wheel to the right fork stop and then feed the connector up through the opening in the front of the lower fork bracket and connect it to the socket housing.
If installing a new sensor on a frame mounted fairing model first turn the front wheel to the right fork stop and then connect the front wheel speed sensor connector and feed the connector under the main wiring harness conduit into the left side of the fairing bracket.
In all cases secure the sensor cable and fender tip lamp wires using
three cable straps as follows by capturing the front wheel
speed sensor cable and brake hose at the brake hose lower crimp and then about the middle of the way between the upper and lower brake hose crimps and securing both the wheel speed sensor cable and the brake hose along with the front fender tip lamp wires, if is has a fender tip lamp. THEN about 2.5 in. (63.5 mm) below the brake hose upper crimp secure the front wheel speed sensor cable, the brake hose and again, if there is a fender tip lamp, the front fender tip lamp wires. The I insert the front wheel speed sensor cable in the clip by pushing on the lip at the rear of the clip to disengage it from the bracket, rotate the tab stamped ABS rearward until the clip is perpendicular to the bracket and install the cable and then rotate the tab forward and apply pressure until the lip engages and then gently pull the cable to verify that the clip is installed properly.
Jun 04, 2014 | Harley Davidson ST3s ABS Motorcycles
Callaway crosstrax push cart front flat repair
I too searched the internet. I have Calloway Crosstrax push cart. I put too much air in front tires and it blew. Be sure to put only 28psi of pressure in that front tire. These tubes cost at least $10. I Finally figured it out how to take this darn wheel off to replace tube. After 2 hours and revisiting after having a beer it came to me. Remove the two screws on each side of the wheel. Unloosen hex screw at bottom of fork. You don't have to remove the hex screw and not sure if it has to be unloosened. The key is to get pair of grip plyers and pull those black end caps out. A little on each side at a time. The tire assembly comes right out. Don't forget to release brake from closed position. Hope this helps.
May 06, 2014 | Optics
REMOVAL OF FRONT WHEEL BEARINGS
Front (4 Wheel Drive) To Remove:
  1. Raise and support the vehicle
  2. Remove or disconnect the following:
    • Tire and wheel assembly
    • Rotor (See: Disc Brake Rotor)
    • Wheel speed sensor and brake hose mounting bracket bolt from the steering knuckle
    • Electrical connection for the wheel speed sensor
    • Front drive halfshaft assembly (See: Halfshaft)
    • Hub and bearing assembly
To Install:
  1. Clean all corrosion or contaminates from the steering knuckle bore and the hub and bearing assembly
  2. Lubricate the steering knuckle bore with wheel bearing grease or the equivalent
  3. Install or connect the following:
    • Hub and bearing assembly mounting bolts and tighten the hub to knuckle bolts; Torque to: 133 ft. lbs. (180 Nm)
    • Wheel speed sensor and brake hose mounting bracket bolt to the steering knuckle and tighten the bolt; Torque to: 106 inch. lbs. (12 Nm)
  4. Torque the lug nuts to specification
  5. Test drive the vehicle to confirm the repairs
Aug 03, 2010 | 2001 Chevrolet Silverado 1500
It shakes as though it had a flat tire at low speeds...its fine the freeway.
Does your steering wheel wobble at parking lot speeds, or your ****. If either, you have a bad tire, have it checked ASAP. (if steering wheel wobbles its a front tire.)
Dec 10, 2009 | 1992 Mercedes-Benz Mercedes Benz 300 Class
Removing front wheel (flat tire)
The lug nuts are the only thing holding the wheel on, aside from a little rust in some cases. Stand in front of the tire facing away from it, try giving it a swift kick on the edge. Of course, you must exercise caution when doing this. Be sure the vehicle is properly supported and won't fall the jack stand.
Nov 30, 2009 | 1994 Ford Escort
After changing front left flat, abs warning and brake system light went on and speedometer quit working
This Sounds Like The Wheel SPEED SENSOR PLUG @ That Wheel Has Been Dissconnected or Disturbed Try Looking @ Rear of That Wheel See if Flat Tire Dammaged The Plug/or Wire.
Aug 01, 2009 | 2006 Ford Freestyle
S430 Mercedes - Front end shaking at 55+
It sounds like you have either a broken steel belt in your tire or a worn out idler arm in your steering assembly. Other causes may be a bent wheel, a flat spot on the tire or worst case your brake rotor / wheel hub may be loose. If the rotor / wheel hub is loose you may have severly damaged wheel bearings. Good luck...
May 03, 2009 | Mercedes-Benz S-Class Cars & Trucks
Baby Tend Jogger model 9118A needs new wheels
Go to any Auto Parts store or Wal MArt Auto center etc. and buy a can of "Flat Fixer" and fill the tires with it. Problem solved :-)
Jul 27, 2008 | Baby Trend Expedition LE Jogger
Sun Mountain Speed Cart V1  Logo
97 people viewed this question
Top Sun Cycling Experts
Tom Chichester
Bill Boyd
Donald Ayers-Marsh
Are you a Sun Cycling Expert? Answer questions, earn points and help others
