Question about Whirlpool DU1300XTV Builtin Dishwasher
What wrong with my Whirlpool DU1300XTVQ1..Pots & pans LED on & Dry Heat Led on but won't do anything except drain...Pots & Pans Led light will come back on blinking then the P & P & Dry Heat will stay on
SOURCE: pots &pans normal sani cycle lighs
If it is a slow blink on the start button it's something to do with your door switch. If it's a rapid continous flashing it's prob a short in your key pad. If it flashes 7 times, pauses and then repeats you have a fault with your heating element.
If it's a short with your key pad and the unit has water in it - stopped mid cycle you can cut the power to the unit at the breaker, open the door controls up and disconnect the 14 pin key pad connection. There should be a wiring diagram in the toekick cover (at the floor). This diagram will tell you how to do various tests, disconnect the key pad. If your not a handy type person call a repair man and tell him you think youhav a short in your key pad.
Posted on Mar 11, 2010
  • 10 Answers
SOURCE: pots and pans light, quick
Try to pull the fuse or turn off the breaker for 30 seconds. This should reset the electronics and possibly fix the problem.
Posted on Sep 08, 2010
oldTech2332
  • 2341 Answers
SOURCE: the panel is stuck on pots/pans for cleaning and
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Posted on Sep 06, 2011
  • 3247 Answers
SOURCE: whirlpool quiet partner III pots & pans light
test
Posted on Nov 03, 2011
  • 16 Answers
SOURCE: pots and pans and normal lights blinking
That reset sequence code didn't work for me. We tried everything on a ton of forums.
What I did to fix our Whirlpool dishwasher was to disconnect the drainage tube from the garbage disposal. I noticed it smelled really bad so I figured it was clogged. I used a bucket to catch the water left in the tube. I took the sprayer from the sink and flushed out the tube. 4 pumpkin seeds and a couple of beans landed in my bucket. I flushed it a couple times. I hooked the tube back up to the disposal and sure enough all the lights returned to normal. I pressed start and it came on.
Posted on Nov 16, 2011
Quiet Partner IV. Why is the pots and pans light blinking and it won't run?
Its normal for the drain pump to run for 5 to 15 seconds and then your washer should fill and you wash pump should run if your was pump is not running and just makes a humming sound then your start capacitor may need changing see the link below this is a simple task and not expensive. When ordering a new capacitor make sure it is the same size in ?F.
Washer Motor Capacitor part 8572717 How To Replace
May 28, 2015 | Whirlpool Dishwashers
Wy is top rack not washing
top rack is for small plates & cups not pots & pans as they may obstruct the rotating of the sprayer & foul the water from getting to all the items
Aug 31, 2014 | Bosch Dishwashers
My Whirlpool Dishwasher DU1300XTV
Heating element goes bad causing the controller to go bad as well
May 14, 2014 | Whirlpool DU1300XTVQ Dishwashers : Built...
Wearever pots pans repairs
This is the wrong paragon. Paragon popcorn machines have only been around for approx 15 years. They were GMI prior, and did not make pots and pans.
Apr 23, 2014 | Paragon Kitchen Appliances - Others
Whirlpool du1055xtss3 not working
I dont know if this indicates a malfunction or not. One user manual may cover several years while many modifications can take place. Ask yourself if any other part of the process can contribute to this. You have electricity to the control board or it will not flash these display indicators.
Is the water on?
Is the waterline kinked under or behind the machine?
Is it connected to hot water? A heater raises the hot water quickly but cold water takes alot longer to reach operating temp. Since the hottest program id pots and pans, this may indicate the heater is bad but since you were able to change the display to pp and normal I think you entered into a controls sequence that technicians can do to make changes to some parameters like temperature setting or water hardness. See if you can get a whirlpool tech to break the grip on his service manual and send you a page by email. Good luck.
Apr 23, 2013 | Dishwashers
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
Unit will not run. cannot enter diagnostic mode.
i would say that you have a bad touch panel..99 percent positive
May 10, 2010 | Dishwashers
Cycle buttons work, option buttons dont, Cant deselect heated dry, Wont start
The part is covered by warranty. However, the labor is not and Whirlpool will not replace the part without having someone service the unit. Every place I checked wanted $100 just to come out and tell me what was wrong. Any service would be extra. Seems like Whirlpool figured out how not to stand behind its products. They should be held accountable.
Dec 27, 2006 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool DU1300XTV Builtin Dishwasher Logo
18 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
