Question about LG Televison & Video
Tv lg adjust remocon 105-201m - LG Televison & Video
My lg tv is overfilled, it cuts people off on the top and cuts the bottom off. How do I get the picture to fit the screen
Its pretty easy check your remocon for the button that writes
ratio press it continiouly until you find the 16:9 ratio
hope you get it right
George (ratio button usually is on top right of you remocon )
Sep 22, 2016 | LG 47LG50 47 in. LCD HDTV
HOW DO I USE SIPLINK ON A LG 42 LCD
Simplink is used only with two or more LG deveces connected together via Hdmi
To use it you should first of all turnit on
you go to option and select simplink on or you just press from your remocon the simplink button and then select on
After this when you press the simplink butto to your remocon
a new menu with your connected devices pop upwith new selections to use
Jul 18, 2014 | LG 42LC2D 42 in. LCD HDTV
How do i access the service menu
Try with ok and ok from the tv set and remocon
or also try menu and menu
but to inform you this works with specific suffix for your tv
hope that was helpful
Jul 12, 2014 | LG 32LG30 32 in. LCD HDTV
Lg 37lc5d service menu
try ok from the remocon and ok from the tv set
or menu and menu the same way
Jul 11, 2014 | LG Televison & Video
How do I access the lg 55la6200 service menu?
you need a service remocon to do this there is no other way
(I mean there no other way pushing buttons etc )
Jun 14, 2014 | LG 55LA6200 55" 3D 1080p LED-LCD TV - 16:9...
Lg adjust remocon 105-201m manual
como programo un control remoto rca a un dvd speler spdv107
Jan 28, 2014 | LG Televison & Video
How can I program my remote to a blue-ray device
hello erick 5412,
Just a simple way , no need to program .
If you connected you TV with bluray use a HDMI cable, you can operate TV and bluray in one remocon. Set your HDMI CEC on, it will initial connection a moment. After that connected you can operate tv and bluray at a time , like power on off, play, etc.
Thanks.
Mar 23, 2011 | LG 42LC2D 42 in. LCD HDTV
Universal - remocon settings
I need the code for the Sumsung Universal Remocon for my Samsung TV model TXN2726. It is an older TV 2003 model. It was given to us recently but the remote needs to be programmed and we weren't given the programming code.
Jan 20, 2009 | Samsung TXL2767 27" TV
PICTURE TO LARGE FOR THE SCREEN AND ZOOM ISNT FIXING IT
Your TV set may have settings for picture size ratios but also if you have cable or sattelite service, they too may have these settings. Try both TV and cable remocons for proper adjustment
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
JVC AV-27230 27"
Mike,
Go into menu settings, closed caption and turn off closed caption... What you're seeing is the text box of closed caption.
Bill
Nov 23, 2007 | JVC AV-27230 27" TV
Televison & Video Logo
106 people viewed this question
Computer Repairing
Computer Repairing
