Question about Brother MFC-8480DN All-In-One Laser Printer
How do you reset toner cartridge - Brother MFC-8480DN All-In-One Laser Printer
How do you reset counter on Toner for TN-360
No, If you use a refill in your recent toner cartridge you need to reset the toner, if you use a new toner cartridge, no need to reset.
Aug 28, 2014 | Brother MFC 7840W Printer
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
I have a Brother Laser Printer HL-5350DN. I refill toner myself but the toner light will not go out. How do I reset it so it goes off?
There is a reset gear in the cartridge that needs to be "reset" or replaced. I've included a link to a PDF file that goes over the procedure to properly refill and reset the toner cartridge. This is a document that is used by a company that does a complete rebuild, so you probably won't need most of the information, just the part on resetting the reset gear.
http://www.uninetimaging.com/downloads/technical/TecArtWebAdded/Brother_HL_5300_Series_tn650_Reman_Eng.pdf
Apr 05, 2011 | Brother HL5350DN Laser Printer
Reset printer
The toner cartridges for the 8026 have a chip on them which count the amount of toner being dispensed from the toner cartridge.
When the printer counts the amount of toner being dispatched from the cartridge has exceeded the amount of "usable" toner in the cartridge, the printer will display the error showing the toner cartridge needs to be replaced.
Crucial the printer also "writes" to the chip on the toner cartridge to say it is empty----You can no longer use this cartridge by simply refilling it.
You need to replace the toner cartridge on the printer with a Genuine New 8026 toner, this should then clear the error automatically and the printer will again spring back to life.
If you are using a new toner you may;
  1. Have a faulty replacement toner
  2. Have a blockage in the pipe which takes the toner from the toner cartridge to the drum unit
  3. Have a fault with the toner dispense motor
Jul 20, 2010 | TallyGenicom 8026DN Laser Printer
Toner exhausted replace toner message in laser printer
Remove the empty toner cartridge and replace it with a new toner cartridge or a recharged cartridge. New toner cartridges can be purchased from the place where you purchased the printer.
Feb 03, 2010 | Samsung SCX-4300 Monochrome Laser...
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Dcp 7020 and 7040 toner life end message premature, need override
When the Toner Life End LED flips on, requires you to replace the cartridge, even when there's still toner left in the cartridge. The machine detects end of life by shining a light through from one side to the other.
To circumvent the detection mechanism, remove the cartridge and put a piece of masking tape over or jam a little bit of paper into the clear opening/circle on the right side of the toner cartridge, and then pop the cartridge back in. Eventually, you'll start seeing streaks, and then you'll know that the cartridge is truly empty.
Jan 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Brother MFC-8480DN All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
