Question about Jensen XS-1010 Car Subwoofer
Need box dimensions for Lanzar optidrive 12'' subwoofer.
Ported box dimensions for Lanzar opti1233D 12'' subwoofer. Need port dimensions and box dimensions.
Need box dimensions for 12 inch performance technique icbm-5912 car subwoofer
I have the same sub on the "digital" amp from the same company.
I used the 1.75 ported box from my jl 12w3v3-4 and it sounds great. I am not sure on the correct box size but the box for the 12w3 sounds great. I tried emailing performance and the email was wrong.
Feb 26, 2012 | Performance Teknique ICBM-5912 Car...
What air space for a sealed box should i use for my lanzar max10d subwoofers
a sealed box is designed to handle more power with a smaller box. to get max efficiancy or spl bass it is recommended to go with a ported or vented box but your speaker can't handle as much sometimes 200-300 watts less but bigger bass. so, sealed box is 0.85cu.ft-1.25cu.ft and vented or ported is 1.25cu.ft-1.75cu.ft.
Feb 01, 2011 | Lanzar MAX10D Car Subwoofer
What is the best size speaker box for this subwoofer
Any type BOX will do...This ensures all the thump to be pushed forward to give all the sound from the speaker forward....enjoy. Alow enough room to get you hand in to wire easy and you should be good.
Dec 27, 2009 | Sony XS-L122P5 Car Subwoofer
What size box do i need for a cerwin vega v124 and ported or sealed
Hi there, If can you give me an average dimension of your trunk your installing it in. And Ported - Sealed is really based on what you are trying to achieve in the vehicle. Ported in my opinion sounds better in cars with an enclosed trunk where as a sealed subwoofer plays better in a hatchback vehicle where the car itself acts as a second box.
Nov 15, 2009 | Cerwin Vega 124 Car Subwoofer
What is the rms for a single max12d lanzar is it 500rms or 250rms
Description One of the oldest and most respected names in automotive sound is also one of the most consistent winners on the competition circuit. Lanzar offers a wide range of high performance subwoofers, from the pounding OptiDrive Series to the rugged MAX Series. The MAX12 dual-coil subwoofer offers high power handling, great bass response, an economical price, and a 3 year warranty. Specifications: *Power handling: 500 watts RMS/1000 watts peak *VCdia: 2" *Impedance: 4 ohms per coil *Magnet weight: 130 oz. *Fs: 33.6 *SPL: 88 dB 1W/1m *Vas: 3.19 cu. ft. *Qts: 0.47 *Xmax: 10mm *Dimensions: A: 12.09" B: 11.15" C: 6.42"
Oct 27, 2009 | Lanzar MAX12D Car Subwoofer
15" Lanzar 400 watt sub
you would have to build a ported or sealed box with a sloped back
Sep 19, 2009 | Lanzar OPTI1222D Car Subwoofer
I HAVE TWO 15" MEMPHIS SUBS AND A POWER ACOUSTIK 1440 AMP. I AM PUTTING THEM IN MY 2002 SUBURBAN, WHAT IS THE BEST BOX TO USE? PORTED OR VENTED
that mainly depends on the type of music you will be listening to. If you need clean, punchy bass, use a sealed box. For more growl, and louder bass, use a tube ported or slot ported box. I would not recommend a bandpass box for 15"s but they do make them. I have 2 kenwood 12"s in seperate slot ported boxes with a SPL 1500 watt amp, making about 149Db in a 93 Eclipse. Let me know if this helps :)
Jun 15, 2009 | Lanzar OPTI1222D Car Subwoofer
Building a box, need to know best dimensions for box and port
Hello dirt_digger6,
The specific sub you are asking about would seem to be the TS-302F which is the only 12" 800W Pioneer I have located.
Directly from Pioneer's support knowledgebase:
TS-W302F = Ported: 2.5 Cu.Ft. F3 = 39HzPort: 4  x 6.5 tuned @ 37 Hz with 12 % port noise.
An enclosure 16X18X21, constructed from 3/4" MDF will yield 2.69 Cu.Ft., allowing .19 Cu.Ft. displacement for the sub and port.
There's an excellent "box calculator" located here on the12v.com web site. You can measure the space you have to put the box and fiddle with the dimensions to get close to your ideal volume. There are also calculators on the12v.com which will allow you to calculate a port length based on port diameter (or width/height), enclosure volume, and desired tuning frequency.
Hope this helps.
May 07, 2009 | Car Audio & Video
Box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Feb 14, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Box dimensions
I've Got The Same Subs, I Got A Formula On The Net, Its Dimension Is Aprox 9 D X 24 H x15 W.
Although I Have Them In A Home Made Ported Box I've Made, Its Dimensions Are 8 D X 23 H X 17 W And Its Sound Pretty Damn Good. I Have A 2 Inch Round Port X 6 Inch Long. The Formula Says I Should Have A 3 Inch Long Tube.
Feb 23, 2008 | Volfenhag ZX-4712 Car Subwoofer
Jensen XS-1010 Car Subwoofer Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
