Question about Pride Mobility Products Pride Mobility Celebrity X 3 Wheel Electric Scooter
Nomad scooter heartway pf3 removal of brace is preventing removal of battery cover
What does error09 mean on my 'Mystere' Heartways scooter please.
hi Adrian,
Is this the scooter you 're referring ? in that it is a Rhino controller and the code means a internal fault with controller ? are you located in the UK ?
Regards
Rob
Feb 26, 2016 | Health & Beauty
How do you operate the bolero mobility scooter?
hi ,can you located the controller , normally located at the rear of the scooter , wires from the motor and brake go to this unit..
Once i ID the controller i can help with the correct advise for you ...
Regards
Rob
www.gewizrepairs.co.uk
www.facebook.com/gewizrepairs
Feb 24, 2015 | Heartway Bolero Red Power Scooter - PF2
How do you remove the seat?
try lifting straight up when you lift the swivel lever.
Jul 04, 2014 | Heartway Rumba S - HP4
I have a IMC Heartway Gypsy and the power light blinks 5 times and the scooter won't run. I have just replaced the batteries. Is there list of what each code means? Thanks
1. Battery low
2. Battery charge is too low
3. Battery voltage too high or charger still connected
4. Current limit. turn scooter off for a few minutes and then on
5. Brake lever in freewheel mode
6. Throttle lever not in centre on switch on or faulty
7. Speed pot or throttle pot error
8. Motor volts error
9. Other internal fault/control fault
Hope that helps you.
May 18, 2014 | Pride Mobility Products Go Go Ultra X 3...
Looking for user manual for heartway royale 4
Please see the link below. It may not say Heartway, but it's the exact same scooter, but now imported into the UK by Drive Medical.
http://www.drivemedical.co.uk/files/9cbeb3d2-b61e-4676-8ab2-a08300c3f668/Royale_IFU.pdf
Mar 25, 2014 | Health & Beauty
I need a user manual for my mobility scooter heartway royale 4
Try sales @ a1mobility . com and talk to a representative.
Mar 24, 2014 | Coffee Makers & Espresso Machines
I need a heartway royale 4 manual for my mobility scooter
Try & visit the Manufacturer Website & see if you can Download 1 as a PDF File to save.Good luck
Mar 24, 2014 | Electric Mobility Mobility Electric Power...
Heartway power wheelchair chirps and blinks red button in "key" location as if locked. It will not do anything else. Them after a while it chirps and the flashing red light turns off.
some chairs have a magnetic key, if yours is one of these, try using a standard magnet, you may find the key you have has become de-magnetised. a standard magnet should unlock it.
Sep 09, 2013 | Heartway Rumba SF - P4F
My batterys and charger are fine. but when i leave to go down the street it goes dead and the motor is hot. dont know what to do or where to take it and my money is stretched to its limit. can u help
Bonton you don't say if you are getting flashes on your console when the scooter stops. Did you purchase the scooter or did Medicare? If Medicare paid for it they will pay for most of the repair cost Since your scooter has an electric motor it will get hot when using it . How old is the scooter? If your batteries are good then you could be in need of brushes for the motor which are cheap considering the cost of a motor. you can call Repair Xpress @ 1-877-581-3733 to see if they have a tech in your area that can check the scooter for you and the cost should be reasonable. I hope this helps you. Let me know
Sep 12, 2010 | RTO IMC-Heartway NOMAD3 Nomad 3-Wheel...
Layout
http://www.imc-heartway.com/pdf/hp3.pdf
http://www.imc-heartway.com/pdf/p4f.pdf
Here's two manuals for the two Rumba models available; they have two similar to the first one, a Heavy Duty and a Light Duty, but basically the same.
Jun 10, 2009 | Dmm IMC Heartway Frontier PF1 4-Wheel...
Pride Mobility Products Pride Mobility Celebrity X 3 Wheel Electric Scooter Logo
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
