Question about GE AGQ10AJ Wall/Window Air Conditioner
Where is the reset botton on the ge air conditoner
We have a kolin S Series air conditoner it displays an F2 error code only fan is working no air con
Try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you have any other Air Conditioning Repair Questions don't be afraid to let us know.
Feb 28, 2014 | LG Heat cool Window Air Conditioner
Air conditoner making noise
Take off the front cover and see if ice is on the coli if so you might trie to clen the coli if that dose not work the have some one look at the ref shod be r22
Aug 20, 2012 | GE Electronic Room Air Conditioner AGW12AH
My window air conditoner is leaking water inside and what can I do to prevent that?
Make sure the unit is tilted down at the rear at least 1/4" to 1/2" and that the drain hole in the drain pan, under the rear of the unit is not clogged. The drain hole can be hard to find, as clogs blend in with hole. So, be persistent in looking for it.
Hope this helped you Elaine. Thanks for choosing FixYa.
Jul 23, 2011 | GE AJCQ08ACB Air Conditioner
I need a filter for my fedders air conditoner. Fedders A6T12F2A-A filter part no. CRC111707770001. I cannot find one.
Filter, sorry this part is no longer available, with no sub and we have none in stock.
Apparently they no longer make it.Wal mart does sell filter material,and filters that you cut to size.The cut to size is what I would use.It comes mounted on a plastic grid,so it works great on window units and central ac systems.
May 19, 2011 | GE AJCQ08ACB Air Conditioner
Air conditoner quit blowing cold air while driving home
you can try recharging the system...it's a fairly simple process and freon can be purchased at any parts store. here is an overview:
http://www.aa1car.com/library/ac_recharging.htm
Jun 24, 2009 | 2004 Ford F150
Do rheem air conditoner hair a reset button
The older unit have a High pressure reset at the outside unit, About center bottom by the copper lines. Push to see if it starts. If it resets you may have a dirty condensor coil. Wash good with water hose. Turn power to outside unit of first.
Jun 06, 2009 | Ruud UAKA037 Air Conditioner
Keep needing to reset washer dryer
Check the vent lines to be sure the path is clear
Mar 13, 2009 | GE WSXH208A Front Load Washer
Delonghi Pinguino Classic Portable Air Conditoner Works for 30 min then red light comes on
Have it serviced. It cost me $250 to have a pro do it. Also, check the timer (the dial is hidden by a sliding cover on my unit). My husband cleaned it himself a year later and he took it apart to do it and it works much better now. When he opened it up, it was full of calcium deposit and dust. He told me he did not think the unit had been cleaned properly by the pro.
Jun 19, 2008 | DeLonghi PAC85 Portable Air Conditioner
GE AGQ10AJ Wall/Window Air Conditioner Logo
20 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
