Question about True T-35
True model t-35f freezes up - True T-35
    Novelist:
    Scholar:
  • 187 Answers
If you have the thermostat set too low it will freeze up. Make sure you have a thermometer that works in there to monitor the temperature after you thoroughly defrost the coil. No lower than 35 Degrees f. Also keep the doors closed as much as possible. If you've done all of this already and it still freezes up consider checking the cooling coils making sure they are clear of dirt, dust, paper and wrapping debris. If you did all of that you may have an improper refrigerant charge. The old "hit and run" refrigerant charge can work on air conditioning but almost never works on restaurant equipment. Make sure its evacuated and recharged with the exact amount of refrigerant by the ounce. Its called a critical charge for a reason. Hope this helps and good luck.
Posted on Oct 18, 2014
True gdm35 evaporator fans not working?
change the fan motor, if the fan dont wonrk wont spread cool air
Sep 18, 2014 | True Display Refrigeration GDM-35F
Freezer turns back on quickly
check your temp setting. it hould be running between 0 to -5 degif it is running colder than that dajust the temp. if that does not solve the problem
replace the temperature control.
Dec 26, 2012 | True 35 cu. ft. / 991 liter Commercial...
True freezer T-35F shoudl it be running hard all the time?
Check and clean condenser regularly, check thermostat set at 2 or 3 and check fan is working ok. Apart from that, check the evaporator isn't frozen solid with ice.
Jul 01, 2012 | True 35 cu. ft. / 991 liter Commercial...
True freezer T-35F. outside the door around the seal is too hot. it took a long time for new food to freeze or not frozen at all. fan seems to be running.
You have check if the fan underneath is running? Or maybe it is starting to go bad and only runs sometimes and sometimes it does not?
May 28, 2011 | True 35 cu. ft. / 991 liter Commercial...
Our True Freezer quit cooling properly. I'm not sure which model it is. Serial # is 10883769-6876. It is at least 13 years old. We would like to know who we could call to service it. Our location is...
Use this link for the True website fill in your zip code
http://www.truemfg.com/ServiceCoLookup.aspx?language_id=1&event_id=401&from=food&Country=USA
It may be more cost effective to find your local reputable fridge guy, True are a standard refrigeration unit and most parts are generic
Hope this helps
Gordon
Apr 12, 2011 | True 35 cu. ft. / 991 liter Commercial...
I NEED A WIRING DIAGRAM FOR A TRUE FREEZERG M# T-35F
only way to get the exact one is to contact Ture at truemfg.com. They will ask for model and serial and send it to you.
Hope this helps.
Mar 16, 2010 | True 35 cu. ft. / 991 liter Commercial...
My true freezer model T-35F 3/4 HP start run
overamp condition. Sounds like the first place to look would be in the start components.
http://www.truemfg.com/pdf/InstallManuals/T-SERIES/t_series_english.pdf
check out this web site. It has your manual with trouble shooting guide. It also says to check start components. Don't get circuit breaker confused with unit overload. Overload is on the compressor.
Hope this gets ya going.
Mar 07, 2010 | Freezers
Hi, there is a Ductless LG Model # LA180CP that has freez up problem. Sometimes it freez up after 3 days working and some times after couple of hours working. Freez up start from indoor unit. Average of...
what refig and where are the pressures. freeze up is always low charge or lack of air flow and always occurs at the evap. Once it starts and you loose surface area you have to defrost manually
Aug 09, 2009 | Heating & Cooling
True freezer gdm 35f to cold
you just have to change the temperature control. I recommend using a white rodgers part no. 1609-105 set the cut out to about 33 cut in at 38 or 39 you might have to set defrost time to less minutes about 5 or 6 if coils dosent frezze with the setting i gave you. the bulb of the temperature control can be placed on the border dof the difusser.
Apr 14, 2008 | True 49 cu. ft. / 1388 liter Commercial...
True T-35 Logo
69 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
