Question about Nokia N72 Cellular Phone
Camera on standby open lens cover
Camer on standby open lens cover
  • 258 Answers
Take off the lens cover?, the cover blocking the actual camera lense, this is preventing the startup of the camera or your getting a black screen window right, or slide the cover that over the lense across
Posted on Jun 23, 2009
    New Friend:
Camera on standby open lence cover
Posted on Aug 22, 2013
Camera won't turn on
replace batteries and check again
Jul 03, 2012 | Konica Minolta DiMAGE G600 Digital Camera
Hi, my camere picture is getting unclear. Is it possible to clean the lens or change the lens cover. Or do you have other solution to my problem. The camera is 6 years old Regards Preben Keim
Remove the lens cover and see if the picture gets clear, if so the camera has gone weak and it is better to get the latest higher resolution type. However if this is clearer then you can clean the lens using lens cleaning solution and then change the lens cover.
Jul 07, 2011 | Toshiba IKWB15A Network Camera
I have nokia N72, camera is not working, after opening lens cover camera does not start, when i start camera going through imaging>camera, it shows the message "camera on standby, open lens cover" need...
@ above
dude im also facing da same problem( with N72)...hv u got any solution..coz i can see that ur post is almost a month old...so if u hv any solution then pls temme..
thanks..!!!
Sep 29, 2010 | Nokia N72 Cellular Phone
I was running down a muddy hill and slipped after i got changed out of the muddy clothes i went to clean my kodak easyshare M753 and the len cover wont close and when i went to turn it onn the lens got...
thats the same problem i have.......when i turn the camers off the lens opens, but when i turn it on the lens closes to where there is only i lil' **** IT IS SO FRUSTRATING!!!!!! can anyone help us??
Jun 14, 2009 | Kodak Easyshare M753 Digital Camera
Lens won't come out
If the camera is powering on as indicated by a normal screen, you can sometimes coax out the lens by rapping the camera against the heal of your other hand, or a hard surface covered with a cushion, like a double with towel.
The idea is to try to free it up without damaging the camers. This problem is common on cameras if dropped or have a few years on them. It is even more common for the Lens Cover on the TZ3 to behave this way. If it is the plastic lens cover that won't open, you can coax it open with a toothpick and if it closes again, I would just carefully pull this plastic cover right out and as a manual plastic cover that will fit the lense.
In any case, it is getting dated by the TZ5, so an alternate is to sell the defectic TZ3 on Ebay and buy a newer TZ5, new or used, on ebay to replace it. Reparmen buy popular cameras like the TZ3 to fix and resell them. If you have everything that came with it, including the box, it is probably worth $40 as is.
Dec 14, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Kodak Z700
Tentative solution:
I had the identical problem. I went as far as disassembling the camera ... not recommended.
Instead of fussing with the lens cover, I pressed on the lens assembly (gently), the lens retracted and the lens cover closed.
My camera works now. It will be my last Kodak.
Good Luck,
Mike
Jun 08, 2008 | Kodak EasyShare Z700 Digital Camera
Canon sliding lens cover door
I have been having the same problem. Once opened, the sliding door will not close and the lens won't retract. But I have found that if you plug the camera into a computer via a USB, the lens then retracts enabling you to close the lens cover.
I'm still trying to find a way to fix this problem, since this is a great camers and still takes fantastic pictures.
Apr 21, 2008 | Canon PowerShot S50 Digital Camera
Olympus 710 lens won't open
I had the same exact issue. LISTEN UP I CAN FIX THIS. I began disassmbly and removed the outer shell of the camera (after I realized my warranty was no longer valid of course). I found that with the majority of the outer shell removed the lens opened again... Hmm I thought, Curious.
I will cut to the chase. My theory: the "waterproof seals" don't allow for an adequate change in volume within the sealed cavity when the lens is fully opened. You can see the seals going concave and convex as the camera struggles to open the lens. it can't. I am not sure why this issue develops over time. But who cares I have an easy way to fix it.
SOLUTION: Break the seal every time you open your lens. Sounds like a bad solution at first. EXCEPT you can break the seal by simply opening the DC USB port that you would normally open download you pics. So just right of the dial pop open the DC USB cover. Turn on your camera opening the lens and take as many pictures as you want. Also once the lens is out feel free to close the USB port cover to prevent water damage.
PEACE
Dec 01, 2007 | Olympus Stylus 710 Digital Camera
Canon A530 lens cover
it need to be service now..may be there something that clog to the lens cover that why is not opening properly..try to clean a compressed air the lens cover...
Aug 17, 2007 | Canon PowerShot A530 Digital Camera
Nokia N72 Cellular Phone Logo
659 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
