Question about Ruud UAKA037 Air Conditioner
How can i find the mfd. for a rheem water heater model # G1681000, serial # 116872441
I need a serial number for the flame sensor. I cannot locate handboodk
-Generally you have to call manufacturer with model and serial number.
http://waterheatertimer.org/Water-heater-manufacturers.html
-However, Rheem, AO Smith, and Bradford White manufacture most water heaters, and each has parts resources.
-AO and Bradford post their resources under manuals.
http://bradfordwhite.com/documentation
http://www.hotwater.com/resources/product-literature/
-While Rheem hides their parts lists on obscure link, hoping that you will call for a service recommendation.
Here is 2011 parts manual for Rheem
http://waterheatertimer.org/pdf/Rheem-Parts-Guide.pdf
Gene
Water Heater Timers Save Money
Mar 18, 2015 | Water Heaters
Bought a rheem rete 13 off ebay
Question posted under Rheem tankless water heater:
Call Rheem at 800 432 8373
They will need serial number located on label on side of unit.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Usually I recommend that people tear out their tankless water heater and sell it on ebay, and then install tank-type heater from different manufacturer:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
I would be very reluctant to connect used gas appliance without a product manual, and service manual.
http://waterheatertimer.org/images/Exploded-house3.jpg
Mar 19, 2013 | Rheem Tankless Hot Water Heater...
Can I replace the igniter on my rheem water heater RHLP
1) Rheem does not post service manuals for their brands of tankless, or tank-type water heater:
Replace the thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
2) Probably you can call Rheem and give model and serial number and they will send part.
However, based on responses at fixya, Rheem most likely will not send instructions.
Rheem does not want customers repairing gas appliances.
3) Go to Bosch website, and track down their service bulletins for possible assistance
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/
Mar 17, 2013 | Water Heaters
Date of manufacture 81v400, serial r1194849014
1) Rheem 81V40 electric water heater ... manufactured pre 2009 ... posted serial number does not match manufacturer
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
http://waterheatertimer.org/pdf/Rheem-Ruud-2009-water-heater-parts-by-model-number.pdf page 5
2) Possible date of manufacture 11-1994
Mar 05, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Need to know the year of my tank RR410T
the age of all water heaters is listed under the serial #, not model #. you will have to call a plumbing supply house that deals in your brand of waterheater, a.o. smith, ruud, bradfordwhite,etc.
Mar 02, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How do I determine the age of my unit? it is a Rheem water heater model 81V-80D
call plumbing supply house with serial #, & model #of your tank. give them the info and if they handle the brand of your tank , they should be able to help.
Dec 27, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
What years were the Rheem 81v40d produced?
You can find age of water heater from serial number located on label on side of tank.
Label also shows tank size, and tank wattage and element wattage
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Serial number decoder:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
For example Rheem serial number 0790...
First 2 digits are month 07 July
Next two digits are year 1990
Rheem site does not show 81v40d
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Dec 26, 2010 | Rheem 65 GAL ELEC Water Heater 6YR Self...
TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL NUMBER 81V52D C SERIAL NUMBER RH 1297B30669 50 GAL US TANK ELECTRIC WHAT IS THE UPDATED VERSION?
I would say your water heater is from the fury series; new model number 82V52-2. I've included a link with my solution that you should take a look at. You could also look at water heaters of a different brand if this one isn't available in your area. Kenmore, GE, and Hotpoint are all very good brands of water heaters.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
May 25, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Ruud UAKA037 Air Conditioner Logo
15 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
