Question about Kitchen Ranges
How can i clean the grease from the fan of nutone range hood model cxw-200-04B1?
My nutone range hood model cxw-200-04B1has grease built up and I want to clean it, please let me know the easiest way.
SOURCE: HI I AM HOPING THAT SOMEONE
I also have this rangehood and have found out that this "Masano" brand is actually from a group called Nationwide Electrics or Electrical. They put out a lot of appliances with different tag names. Try googling for them and you may have more luck. I did find an appliance store that sells the Nationwide Electric rangehood identical to the CXW 200 in Cairns, so there must be others around Australia. I hope this helps.
Posted on Sep 17, 2008
  • 68 Answers
SOURCE: range hood is making noies
use a good 3 in 1 oil. Don't use WD-40 it will only clean it then dry out the bearing. the problem will be worse than when you started.
Posted on Feb 06, 2009
SOURCE: Kitchen Hood Broan Nutone RM5200 Hood won't pull air.
There is definetly somthing blocking the air from escaping, either the duct is blocked or the installer did not remove the metal plate which opens the fan up for it to be able to evacuate.
Posted on Feb 08, 2009
SOURCE: need manual
See http://www.broan.com/ImageLibrary/broan/pdf/InstallGuides/626978B.pdf
and download your manual
Bob
Posted on Apr 26, 2009
  • 10865 Answers
SOURCE: the fan and light switch are not working
I would begin by checking the electrical panel as the circuit breaker or fuse that sends power to the hood may have kicked or blown. If that is not the problem open up the wiring box in the hood. It is unlikely that bvoth switches would have gone bad at once.
Posted on Jun 15, 2009
Bulbs blew on my nutone allure range hood new bulbs does not work. please help
Depends what is wrong.To call a repair man will cost a service call before he starts. Check all your wiring and see if there is a short. See what you can do before you call a repairman.
Nov 04, 2014 | Broan-NuTone Kitchen Ranges
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
I have QS3 series range hood. Fans are not working though lights are okay. When I click the fan buttons it does turn green, with clicking sound however fan doesn't turn on. Please advice
Sometimes they can be cleaned and oiled and they will work again...
Cleaning the grease and dust with out ruining the motor is the tricky part...
Take the unit apart as much as possible...spray down the fan part with a degreaser or strong cleaner...let it soak and they spray it down with water to rinse it off...
Then work a few drops of light motor oil into the motor by proping up the fan so that the oil will run down the shaft and into the motor...
then get it running smoothly by working it by hand...
Put it all back together and it should work again...
heatman101
Jan 15, 2011 | Broan-NuTone Allure III QS330SS Kitchen...
Model 41.000-L range hood. Fan is getting electricity (very soft hum), but fan won't turn. Must it be replaced, or can it be cleaned, or ????
heatman101
Jan 13, 2011 | Broan-NuTone Kitchen Ranges
My Range Hood (Best by Broan K260A) is just two years old in a new house. WHen I use it, fat & grease drip down from the left and right edges against the wall. Can someone tell the problem?
grease accumulation, remove the fours screws on the lower plate, to remove excess grease. further you can unscrew the bolt that are holding the assembly and unplug the unit. after remove fans with allen key and remove motor , clean and reassemble , make shure to put motor the right back the same way. reassemble the same way , problem should be solve for at least 7 years depending on cooking.
Mar 15, 2010 | Broan-NuTone Broan Range Hood Accessory
Humm in system
Called Nutone distributor and found that the unit is guaranteed for life. What a surprise!
Thanks for your web site, I will use you in the future.
Jay
Apr 14, 2009 | Broan-NuTone N-IS-338BL Accessory Intercom...
Hoover ws130
take out the detergent drawer and thoroughly clean. if that doesn't work, the may be a blockage in hose from drawer to tub. take off top, remove hose and clean out
Mar 03, 2007 | Broan-NuTone WS130 Kitchen Hood
Kitchen Ranges Logo
238 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
