Question about Exercise & Fitness
Treadmill mileage check on a techno - Exercise & Fitness
My techno gym treadmill 700 indicates equipment is blocked code (4) how do I fix this problem. Thanks
Can be one of many problems.
Can be as simple as a limit switch not resetting.
Can be a cable is bad
More often than not it's the lower kit (electronics near the motor) that is blown though.
Mar 09, 2015 | True Technogym Excite Run 700 Treadmill
How do I lubricate the c 1800s nordictrack
the only lubrication that needs done is between the walking belt and the deck. if a roller is squeaking either front or rear you can try using wd40 on the bearings on either side
Oct 21, 2014 | Nordic Track Nordictrack C 1800s Treadmill...
We have two commercial treadmills of your company with following details: 1- Technogym Run Exc 700 (Serial # D447ELNAL0000UKS) 2- Technogym Run Exc 900 (Serial # D4492LNAL0000USS) Now problem...
Might be the top panel monitor is faulty Also check that the treadmills are set into km not miles can effect the volt of treadmill and cause errors on treadmill Tip go on to techno gym site and look for display reset something like that and give that a try
Oct 08, 2013 | Exercise & Fitness
Techno woshing macine e2 error code
please adjust the speed sensor, see the diagram , clean it , test for open or faulty, tight the connector very well. Run the software calibration for easy diagnost and fix it.
God bless youca6ac285-0d3b-4f8d-be08-b95be3c0bc40.gif075f693e-e499-4a20-a99a-23cd2bdd1cbd.gif
Jun 06, 2013 | Exercise & Fitness
How do you check actual mileage on a Healthrider r60 treadmill?
I dont believe it is possible. Not many brands worldwide give you this option.
Jan 02, 2013 | HEALTHRIDER R60 SoftStrider Treadmill
Finding total mileage and useage hours on a Life Fitness 9500 Treadmill
unfortunately, is NOT possible, Not miles or kms in treadmills.
You have to buy the eagle eye.
God bless you
Oct 07, 2012 | Life Fitness 9500 HR Treadmill Next...
The equipment is blocked
hi all i have run excite ur 500 treadmill from techno gym company i face block on screen i think it's board problems if anyone can have any idea contact me at email: alex.freemas@gmail.com
May 08, 2012 | Exercise & Fitness
Re: model cx455T cybex treadmill. has "SVC" on monitor, but still functions. 1) how do I get rid of the "SVC", and what does it mean?
hi,
Every 9,000 miles (14,500 km) the unit will show "SVC" on the display. This will continue until the service is performed and the service odometer is reset.
1. Determine mileage.
A. While in Dormant Mode enter Test Mode by pressing and holding the Heart Rate and Level keys simultaneously for five seconds.
B. Press the Dist key. DIST appears on the display. Record Mileage. NOTE: Once the unit exceeds 999 miles or kilometers the odometer will use both screens. Example:
12,805 miles or km would be displayed as 12 805 . NOTE: To exit Test Mode, press the Pause/Stop key .
Every 5,000 miles (8,000 km).
? Check running belt tension and tracking.
? Move treadmill and vacuum underneath..
? Lubricate elevation pivot points.
(Watch the videos for tentioning and lubricating treadmill belt.)
Aug 20, 2011 | Cybex International Exercise & Fitness
How can I find out how many km have been used on my Epic 550 treadmill?
hold the stop button and then insert the key, keep holding the stop button until you see the mileage and hours used, to switch from English measurement to metric just hit speed up button.
Jan 10, 2011 | Epic View 550 Treadmill
Not reading mileage? battery good
Remove the motor cover. Check that the speed sensor (found on the frame near the pulley)is as close to the pulley without making contact as possible. Check the pulley for the small round magnet. Make sure it is present. It may have come loose and is now attached itself to the metal frame.
If all this checks out, the speed sensor may be defective.
Dec 29, 2010 | Treadmill Doctor Weslo Cadence 1020...
Exercise & Fitness Logo
15 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
