Question about Apex Digital PF2025 20" TV
Philips tv volume goes up by itself - Apex Digital PF2025 20" TV
When i turn it on,it goes through the entire menu and won't stop
first check all your push buttons on the TV to be sure none are jammed or sticking, then if that doesn't solve the problem you will need the PCB part# A91F0MPW-001
see the following site for part avail. & price:
https://www.encompassparts.com/item/8098042/Philips/A91F0MPWS001/Main_Pwb%28non-returnable%29
Mar 03, 2015 | Emerson LC320EMXF 32 in. LCD TV
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
I have a philips 40pfl3705d/f7 LCD TV and the volume can be seen onscreen adjusting itself randomly. Tuns on and off by itself and so on all by itself. When it works it works great. But randomly it seems a...
You might need to get this checked with the manfucaturer, looks like a malfunctioning remote control. Or you can just replace the remot and see if that helps.
Nov 05, 2013 | Philips 40PFL3705D 40 in LCD TV
Volume goes down to 0 and the menu goes on and off.
A bad connection on the small signal board may be the problem! Have a Tech check this connection, it may be to tight due to the heat shrink tube. Have them peel it back to reduce the strain! Should work then!
Sep 11, 2009 | Philips 32PFL6704D 32 in. LCD TV
My volume goes up and down without me touching it
try upgrading the firmware of ur player
if ur player is touchscreen try turning off the device for some days
Feb 02, 2009 | Philips GoGear HDD6330 MP3 Player
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
Keeps turning itself on
It's just magically switched on??? Do you have kids? ;-)
Jan 18, 2008 | Philips HTS3500S System
TV Volume goes up when channel is changed Philips 20S240
I don't think the IR sensor has anything to do with it. It sounds like a surface mount micro processor to me...
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Apex Digital PF2025 20" TV Logo
22 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
