Question about Dell Dimension™ B110 PC Desktop
How to add extra memory card in the mother board
I have about 3years old dell Dimension B110 It is getting slower by day. I have been told if I increase memory it will run faster. Is it easy to add an extra memory card if so how do I accomplish it by myself.
Thanks for any help
Bijan
  • 400 Answers
Well u may upgarde your ram to 1 or 1.5 GB if less ... and try installing Windows 7 on your computer i can tell you how to download or if you already have ... then the speed will not bother you any more...
Posted on Jun 23, 2009
    Sergeant:
  • 190 Answers
Save your cash first check if sysem is up to date on drivers and firmware
like bios, HDD, chipset
other is service the CPU fan may be clogged with dust bunnies, use canned AIR blower/duster and unplug fan power plug or hold fan from spinning
for memory read manaul note
Maximum memory
2 GB
DDR333
but want speed update the CPU intel 478 socket. to a higher speed
Dell dimension 1100 b110 drives audio e rede
Hello download the driver here at dell:
http://www.dell.com/support/troubleshooting/us/en/19/Product/dimension-1100
Open the audio folder, and download the driver.
Run the exe program, and reboot after the install is done.
Good luck
Mar 04, 2013 | Dell WF887 - Dell Dimension 1100, B110...
Removed 256 meg card, installed ddr2 1gig card. Computer would not start.
Old system!
Up to 2GB DDR are fine, but you tried DDR2, which it can't handle. Get the right kind of memory (just DDR, not DDR2 or DDR3) and see if they don't get along better.
Jan 03, 2011 | Dell Dimension™ B110 PC Desktop
My dell dimension b110 quit working one day and just flashed an amber colored light. I was told I need to replace the power supply. Is any 400W 20+4-pin ATX PSU w/SATA compatible?
Yes, just make sure it's ATX (not ATX mini etc but you'd see from the connector anyway) has the right motherboard connector and all other connectors. Also I'd go for a 450W as if your 400w died it may have been from a power surge that a 450W or higher would handle better.
Oct 29, 2010 | Dell Dimension™ B110 PC Desktop
Hi i got a ( dell Inspiron vista ) that i cant fix because of a virus - my question is can i use the memory board from that to put in my dell Dimension B110 dell system with XP home edition?
It all depends, if your dell inspiron vista (you didnt wrote the model) uses DDR2 memory you cant, because the B110 uses DDR memory modules (it's an older system). Probably your dell comes with DDR2.
Apr 27, 2010 | Dell Computers & Internet
I have a Dell B110 and the system only recognizes 252Mb of memory. I thought I had a bad memory stick so I installed 2-512 chips. Now System Info shows the 1024 with only 100 available. Task Manager only...
Try to seat one memory first than try the other one. One of them might be defected. Also check the memory slots, ensure they both work well.
I had 2-512mb sometime system just detect 512 and other time 768. Since I replace both with new memory cards they work just fine.
Apr 13, 2010 | Dell Dimension™ B110 PC Desktop
I have a 6 year old dell 2400 pc. The monitor
find out the price and then compare... but in my experience... its cheaper to get a new mother board with the chip and then just install it... in the end... all you are really concerned about is the hard drive... becuase thats where your data is...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 23, 2009 | Dell Dimension 2400 PC Desktop
Dell tech in who-knows-where told me to reinstall operating sys, XP Home. About half way thru, error message, "Windows detected fatal error, shutting down." Tried 2 times more same message. Help! Dimension...
The fatel error is cause by memory/ and or CPU giveing out if the unit is under warrenty then I would suggest having them diagnose it , if its not then purchase some memory with the same spec's and try reloading again.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Dell Dimension B110 PC Desktop
Memory Upgrade Attempt Causes Computer Not to Post
Seeing as the message is indicating a problem at one of the timer checkpoints, fatal is probably an accurate description. You are most likely looking at a motherboard replacement scenario. I've seen improperly seated memory modules toast timer circuitry on old boards back in the days when most of the timing circuitry was constructed from discrete components, not entirely IC-based timing solutions, but I have never seen it happen on modern boards.
Apr 10, 2009 | Dell Dimension™ B110 PC Desktop
Dell Dimension™ B110 PC Desktop Logo
271 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
