Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
How do i remove the bowl and carburetor off a cub cadet lt1045
Cub cadet lt1045 spitting gas from carb where the choke is located I've tried cleaning it but nothing.
Sounds like the carby float or needle valve is leaking. Remove carby float bowl, clean and check.
Sep 26, 2017 | Cub Cadet Garden
My cub cadet modle LT1045 doesn't seem to be getting gas. The fuel filter looks clean. If I spray gas directly into the carb it runs fine but as soon as I stop it dies.
Confirm that the choke is closing completely., Check that the fuel pick up hose does not have a air leak. Confirm that the vent hole in fuel cap is not plugged.(common problem)
Remove fuel line hose to carburetor catching fuel output in a suitable container crank engine and confirm fuel pump is working.
Remove fuel bowl and confirm needle valve is not stuck closed.
Hope this helps?
Fuel Pump
Needle stuck closed
ca4f54cab4d4c1bb583599b331fd2337--small-engine-repair-lawn-mower-repair-u3ralalmkh2yk13xn5gn3lpt-2-2.jpg Check fuel filter
Check vacuum line connection for leaks.
Jul 01, 2017 | Cub Cadet Garden
Cant remove oil filter on Cub Cadet LT1050
grab the filter with a pipe wrwnch or drive a screw driver through it and turn it. good luck. Ron
Sep 14, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet ltx 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a 2007 Cub Cadet Series 1000 Model LT1045 Does this model have a drive belt or is that belt just to run the fan on the tranismission.
hi there pauly46 here your model 2007 and before lt1045
take a look at this web site
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29
this takes you stright to transmssion / belt drive system
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29&dn=0125500003
this diagrams shows belts etc in the drive system , fan, trans etc
your answer is it does have a trans belt it is part number 954-0461
was pt number 754-0461
take a look at this site
cheers hope it helps
pauly 46
Diagram: LT1045+Tractor+%282007+%26+before%29 Drive System 1I136H & before CUB Cub Cadet 954-0461 (replaces 754-0461)
Apr 29, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I don't want to talk to an expret , I lost my manual and I need one to repair my Tractor Cub Cadet lt1045
OK, I won't talk :)
Here is the direct link: http://www.hammerwall.com/Download_Manual/13295/ if the link gives you problems do the following.
Go to www.hammerwall.com and put in Cub Cadet lt1045
Jan 14, 2011 | Cub Cadet Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
719 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
