Question about Logitech WingMan Extreme Digital 3D Joystick
Wingman3d Loss disc ,bought new computor
Re: wingman3d
You can get all the latest software here.
Hope this helps, good luck.
Posted on Nov 24, 2007
0 characters
3 Points
Game has error, says to consult Wii operations manual
It's most likely the disc that is causing trouble. If all of your other games work, it the game you bought. I had the same problem with MySims Party, I went to the store where I bought it, they gave me a new disc, which worked fine.
May 25, 2012 | Nintendo PokePark 2: Wonders Beyond
I inserted in my fifa 09 but the game is not
may be your files are corrupted..plz contact the shop where you have bought the dvd...
Feb 05, 2010 | Microsoft Xbox 360 Controller
Bought attack 3 joy stick -won't do anything
Try unpluging stick from pc,And changing port where its plugged into.
Next try unpluging stick and reboot pc,once pc is started,plug joystick back in.
Thanks and good luck
Jan 12, 2010 | Logitech Attack 3 Joystick
Disc keeps reading an error
the laser lens is most likely dirty.
Found this video on youtube on cleaning it
this one actually shows the guy cleaning the lens:
Note that it basically voids your warranty if you still have warranty on it.
Should solve it,
let me know how that goes,
Jun 03, 2009 | Sony PS2 Dual Shock 2 Controller...
I had the same problems as you and found this answer on blizzard forums.
First, the disc that comes with your ZBoard is now too old to use. The drivers on the disc were made by Ideazon before Steelseries took over, whereas the WotLK keyset was made afterwards. Steelseries seem to have completely reworked the drivers in the interim.
How to Fix
Step 1. Uninstall your ZBoard.
Step 2. Go to and DL the Z Engine.
Step 3. Make sure your ZBoard is plugged in with the standard keyset.
Step 4. Install the new Z Engine.
Step 5. Switch to your WotLK keyset.
Step 6. Run WoW.
I used this solution last night with some success.
Most of the gamer keys now work but some still don't work correctly such as, all the chat buttons default to say.
Hope this helps
Feb 19, 2009 | Ideazon World of Warcraft Keyset for...
Vista and Logitech Force Feedback Joystick Wingman 3D
I tried the above link and it works fine, on a 32-bit Vista. But if you have a 64-bit Vista you might want to try the 64-bit version of this driver, just search around Google for it. Fixed the problem I was having with this joystick not working correctly in Vista (no feedback). Now it works great.
Mar 25, 2008 | Logitech WingMan Force 3D Joystick
PC Game Sims Stopped Working
try to check computer memory RAM
Mar 06, 2008 | PC Game Controllers
G25 ps2/ps3 no steering..buttons & pedals ok
Hi Guys, I have found your solution. If all the buttons work, but the steering does not, it's because the buttons are powered by the USB bus. The electric engine of the wheel need really juice from the power supply. I have just bought a G25 and all the buttons worked fine, but turning the wheel was completely undetected. The power supply was cold as a supermodel heart. I have just put a new power supply and now all the things work perfectly. By the way, my thanks to all the other guys that posted the G25 issues, it really helped me out.
Enjoy your driving !
Sep 02, 2007 | Logitech G25 Wheel And Pedals Set
Logitech WingMan Extreme Digital 3D Joystick Logo
159 people viewed this question
Top Logitech PC Game Controllers Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Logitech PC Game Controller Expert? Answer questions, earn points and help others
