Question about Garden
13AP60TP766 shifter adjustment - Garden
Wiring diagram for troy-bilt model 13AP60TP766
Request the wiring diagram directly from Troy-Bilt.
Sep 23, 2017 | Troy-Bilt Garden
I have a 2002 chevy blazer 2 wheel drive. It has the 4l60e which was just replaced. It goes into reverse in drive and drive in 1st or 2nd its a floor shifter. How would I go about adjusting it? I cant seem...
I have seen adjusters on the console shifters for GM. You have to remove the handle and pull the bezel and boot off the shifter. Where the cable is mounted to the bracket/ floor, there is some adjustment. But there isn't enough to adjust for what your's is doing. This adjustment is for the shifter handle more than an adjustment for the range. The only thing I can think of is that the shifter arm on the transmission isn't in the right position, mounted to the transmission.. Any thing else wouldn't work.
Mar 04, 2015 | Cars & Trucks
How to replace ignition switch on Troy Bilt Lawn Tractor Model 13ap60tp766?
there should be a nut on the key side of swicth cover by a rubber boot take boot off redisconnect on back of switch take of nut remove switch put back together in reverse order
Aug 25, 2014 | Troy Garden
1990 Honda Shadow 1100 hard to shift
Hi, Anonymous and the usual suspects are:
1. Clutch not adjusted properly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. A loose shift lever on shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
infamous third gear Honda Shadow Forums Shadow Motorcycle Forum
Basics to Motorcycle Clutch Adjustment
Honda SHADOW VT1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Shadow VT1100 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 12, 2013 | 1994 Honda VT 1100 C Shadow
Harley davidson shift linkage adjustment
So, I take it you want to adjust the shift linkage and not the height of the foot pedal.
To adjust the shift linkage and not the height of the foot pedal the shifter arm should be tight on the shifter shaft that goes into the transmission behind the primary inner case. The Shifter arm should be positioned with the top end just rear ward of the top transmission cover bolt, positioned there by its placement/orientation on the shifter shaft which is itself positioned by the shifter pawl and spring inside the transmission itself. With all of these components in place as they should be the shift linkage runs from the top of the shifter arm to the front of the bike and the shifter pedal shaft arm. To adjust the length of this shifter rod you will either loosen the lock nut and remove the bolt/threaded shaft on one end of the shifter rod and then loosen the locking nut on the rod at one end (or both ends) of the rod and turn it to lengthen or shorten (increase or decrease) the rod length on one or both ends of the linkage rod until you get it where it just fits into the shifter arm hole(s) again with the pedal sitting where you want it be, re-install all hardware and tighten all hardware etc. If you want the pedal height above a floorboard or if you otherwise just want to adjust the pedal height/position you would not adjust the shifter rod linkage but would loosen and remove the pedal arm and re-position it where you want it and then re-install it and tighten its hardware again etc. Of course you could adjust the pedal height in a small increment by adjusting the shifter linkage if the placement on the pedal rod serrations does not align the pedal close enough to the precise location you want it to be at.
Sep 29, 2012 | 2009 Harley Davidson FXD Dyna Super Glide
2003 FJR 1300 clutch adjustment
Hi, Darrell_kauf and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Clutch Adjustment Technical Mechanical Problems
How to do clutch soak or replacement on Yamaha FJR 1300cc Second generation
Yamaha 2003 FJR1300 Service Manual
OEM parts for Yamaha
Yamaha FJR1300A Owner Manual
Feb 08, 2011 | 2003 Yamaha FJR 1300
I am looking for a wireing diagram for a soloenoid part # 725-142A on a Troy-Bilt 13AP60TP766 Horse (2006)
here is web site for parts
http://www.partstree.com/parts/?lc=troy_bilt&mn=13AP60TP766+Horse+%282006%29
http://www.outdoordistributors.com/MTD/MTDpartslists.html
enter model numbers and select manual download
basically heavy red wire from battery goes to 1 heavy termial on soleniod and the other red lead that is connected to starter motor goes to to the other heavy solenoid terminal
their should be a wire that comes from main switch ( from start mode )
that connects to small solenoid tab and the other tab if it has one will be for a earth ground wire
12 vlt comes from start switch ( start mode ) and energises solenoid
pulls contactor together to make contact accross heavy terminals and sends volltage to starter motor , s/motor turns over engine
cheers
Aug 06, 2010 | Troy Garden
Reverse doesn't work
You need to adjust the linkage so that it goes forward only when it is in FORWARD then reverse will work
Sep 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Shifter issue?
Hi their.Yes there is a place that's not to hard to adjust. Underneath the truck on drives side there is an adjustment there.Make sure nothing was broke in the slamming on the shifter..
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Mar 29, 2009 | 1996 Toyota 4Runner
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
