Question about Canon PIXMA MP160 All-In-One InkJet Printer
Flashing E and the number 2 - Canon PIXMA MP160 All-In-One InkJet Printer
    President:
  • 2,306 Answers
E and number 2 just says to reload paper and try again. Look inside for any paper scraps or things that don't belong..I usually find paper clips, gum wrappers, gummy bears. Around the area where the paper should feed in.
Posted on Jun 23, 2009
    Problem Solver:
  • 20 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi16
Posted on Sep 05, 2009
Non runner on 2013 Eclispe Mobilioty Scooter, red light flashing.
U HAVE TO PUT +61 IN FRONT OF NUMBER TRY THIS NUMBER IN STAFFORDSHIRE 01543 570341 THEY M HELP IGHTI just rang this number & it rang 0249624007.Found this scooter repair in Newcastle contact Peter walz,02 4962 4007 Hi again ring this number they can help u with youre problem 0403 666 613..…,or 1800 726 000. good luck. check all connections between motor & controller 2 flashes,,3 flashes motor has a short circuit to a battery connection contact service center,..,.cheers
Sep 12, 2016 | Health & Beauty
What is service engine light code 12 mean
READING CODES USING MIL (CHECK ENGINE) LAMP
Be advised that the MIL or CHECK ENGINE light can only perform a limited number of functions and it is a good idea to have the system checked with a scan tool to double check the circuit function.
  1. Within a period of 5 seconds, cycle the ignition key ON - OFF - ON - OFF - ON .
  2. Count the number of times the MIL (check engine lamp) on the instrument panel flashes on and off.
The number of flashes represents the trouble code. There is a short pause between the flashes representing the 1st and 2nd digits of the code. Longer pauses are used to separate individual 2-digit trouble codes.
An example of a flashed DTC is as follows:
Lamp flashes 4 times, pauses, then flashes 6 more times. This denotes a DTC number 46. Lamp flashes 5 times, pauses, then flashes 5 more times. This indicates a DTC number 55. DTC 55 will always be the last code to be displayed.
Fig. Fig. 2: Diagnostic trouble code chart (1 of 2)-1995-97 engines
Fig. Fig. 3: Diagnostic trouble code chart (2 of 2)-1995-97 2.0L engines
Jul 26, 2012 | 1995 Dodge Neon
Trouble codes: 1,2,4
dodge codes of this era were 2 number codes not single number codes.recheck your codes flashing on the dash,or with what ever tool your using.there should be a flash close together then a short break then more flashes close together then a longer pause before the next code flashes.cont the flashes that are close together that is one number of the code then after the short pause count the next number of flashes this is the second half of the code.then a new code flashes after the long pause.so if the first code flashes once then after short pause it flashes twice this is a code 12.then a new code flashes after the longer flash,but always a 2 number code.also be aware that dodge uses a code 12 to indicate the start of the code sequence and a code 55 indicates the end of the code sequence.thats why its better to use a scan tool to see what codes are in the computer as sometimes a flash is missed or not counted.
Aug 12, 2011 | 1990 Dodge Ram
I have a 1994 plymouth voyage se and it will not strat. It tell me to check gauge light comes on. what should i do or what does that mean?
Turn key to on ( not start) then off, then on, then off, then on and leave on, and have a pen and paper ready to record flashes of "check engine light". It will flash then pause between second number of 2 digit code. Then a short pause and flash again, pause, then flash. For example: if it flashes 2 times, then pause, then flashes 2 more times, that would be code 22. If it flashes 3 times, pause, then flashes 5 more times, that would be code 35. As I said, there will be a short pause between 2 digits, as well as after number. Write them down as they come up and get back to us with those codes for advice. When you get code 55 ( 5 flashes, pause 5 more ) that means end of message. Those codes should point everyone in right direction of trouble spot.
Jul 31, 2011 | 1991 Plymouth Grand Voyager
I have a Carrier 9200 Series Furnace and it is flashing 2 short flashes and 4 long flashes. What does this mean? Condenser and blower will not come on.,
On the back side if the door there is a Problem list with the numbers next to it. The fast flash will be the first number and the second slow flash will be the second number. It should be #24 which is the low voltage fuse. Located on the board eather a 3 amp or 5 amp fuse.
Aug 31, 2010 | Heating & Cooling
I want to set the time and date on my calculator and need help Please give me the directions
1)Press TIME/DATE and then SET (The first digit of the month will flash)2)Enter the month MM using the number keys.
(The first digit of the date will flash)
3)Enter the date DD using the number keys.
(The first digit of the year will flash)
4)Enter the year YYYY using the number keys.
5)Press SET to confirm the date.
6)Press TIME/DATE and then SET. Enter the time using the number keys and press 12/24 to switch between 12-hour or 24-hour clock.
7)Press AM/PM to toggle morning or afternoon and press SET to confirm the time.
Oct 24, 2009 | Victor 1208-2 Calculator
Check engine codes for 1991 Dodge Spirit LE , light comes on but does not blink then goes out.
Turn key to on, then off, then on, then off, then on & leave it on, (not start, just to on) then count the number of flashes of check engine light. It will flash,then have a small pause, then flash again. It will be a 2 digit number, for example: 2 flashes, pause, 2 more flashes, will be code 22. 3 flashes, pause, then 5 more flashes would be code 35. When you get 5 flashes,pause, then 5 more, That is code 55 which just means end of message. Get back to us with codes & we'll advise of what to look for.
Sep 21, 2009 | 1991 Dodge Spirit
Immobiliser is not turning off and not allowing the engine to start
is it a stick immobiliser?
If your vehicle does not start and the LED continues to flash while the Ignition is 'ON', this means that the Immobiliser system has not recognised the transponder stick.
Simply turn the Ignition 'OFF' then back 'ON' again. If the Status LED continues to flash, move the transponder stick closer to the key barrel until the LED stops flashing and turns 'OFF'.
If the transponder stick on the key ring does not disarm the immobiliser or the
transponder stick is misplaced, you can override the system by entering a 5-digit override number. Each vehicle has a unique 5-digit override number. This number is recorded on the
customer’s owner’s manual. If the customer loses their owner’s manual / override number, the number can be found by locating the vehicle’s Daewoo Stock Number (D.S.N). The customers override number is the last 5 digits of their D.S.N.
Overriding the system using the example 5 digit code 2,1,0,6,2
Important Note: 10 flashes of the Status LED represent the number ‘0’.
1. Remove the Transponder from the Key Ring.
2. With the system armed (LED flashing slowly) Turn the ignition ON/OFF 5 times, with the final position being off.
3. The LED will turn solid red for 2 seconds and then begin to flash.
4. When the LED flashes twice (2), turn the ignition ON. (number 2 was entered)
5. Turn the ignition OFF and wait for the LED to flash once (1) and then turn the ignition ON. (number 1 was entered)
6. Turn the ignition OFF and wait for the LED to flash ten (10) times and then turn the ignition ON. (number 0 was entered)
7. Turn the ignition OFF and wait for the LED to flash six (6) times and then turn the ignition ON. (number 6 was entered)
8. Turn the ignition OFF and wait for the LED to twice (2) and then turn the ignition ON.(number 2 was entered) The LED will turn solid red, which means the system is now overridden and the vehicle can be started. If an incorrect number is entered in, wait 11 flashes then start the procedure again.
NOTE: This is a one-event override. Once the ignition is turned off, the vehicle will passively immobilise after 30 seconds. If your 5 digit override number does not override the system, the chances are that you entered the wrong number. If this is the case, you’ll need to re-enter the override number
and try it again.
Jul 13, 2009 | 1999 Daewoo Lanos
CAR LOOSES BOGS OUT AT HWY SPEEDS AND IDOLOS ROUGH .
Cycle your key on (not start, just on) off, on , off ,on, and leave it on. have paper & pen ready. Watch flashes from check engine light. It will flash quick, pause flash quick. It will be a 2 digit number each time. For example: flash, flash, short pause, flash, flash. is # 22. Flash, flash, flash, pause, flash ,flash,flash. is # 33. There will be a slightly longer pause between codes,(after every 2 digits) then next code starts. 2 numbers again. When you get 5 flashes, pause, 5 flashes = code # 55 means end of message. Check it out and let me/us know what you get.
Dec 31, 2008 | 1991 Plymouth Acclaim
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
107 people viewed this question
old marine
old marine
