Question about Garden
753-05851 shifter adjustment - Garden
Honda CTX700N shifts hard from 1st to 2nd. After 4 or 5 shifts it's normal and good all day but overnight the same problem occurs. Do I need a cable adjustment? @
Hi, Donald and the usual suspects are:
1. Clutch not adjusted properly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. A loose shift lever on shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
coming to stop with DCT question
Shifting issues revisited
Honda CTX700N ND Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CTX700A Owner Manual
Dec 27, 2017 | 2015 Honda CTX 700
I have a 2002 chevy blazer 2 wheel drive. It has the 4l60e which was just replaced. It goes into reverse in drive and drive in 1st or 2nd its a floor shifter. How would I go about adjusting it? I cant seem...
I have seen adjusters on the console shifters for GM. You have to remove the handle and pull the bezel and boot off the shifter. Where the cable is mounted to the bracket/ floor, there is some adjustment. But there isn't enough to adjust for what your's is doing. This adjustment is for the shifter handle more than an adjustment for the range. The only thing I can think of is that the shifter arm on the transmission isn't in the right position, mounted to the transmission.. Any thing else wouldn't work.
Mar 04, 2015 | Cars & Trucks
1990 Honda Shadow 1100 hard to shift
Hi, Anonymous and the usual suspects are:
infamous third gear Honda Shadow Forums Shadow Motorcycle Forum
Basics to Motorcycle Clutch Adjustment
Honda SHADOW VT1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Shadow VT1100 Owner Manual
Dec 12, 2013 | 1994 Honda VT 1100 C Shadow
Harley davidson shift linkage adjustment
So, I take it you want to adjust the shift linkage and not the height of the foot pedal.
To adjust the shift linkage and not the height of the foot pedal the shifter arm should be tight on the shifter shaft that goes into the transmission behind the primary inner case. The Shifter arm should be positioned with the top end just rear ward of the top transmission cover bolt, positioned there by its placement/orientation on the shifter shaft which is itself positioned by the shifter pawl and spring inside the transmission itself. With all of these components in place as they should be the shift linkage runs from the top of the shifter arm to the front of the bike and the shifter pedal shaft arm. To adjust the length of this shifter rod you will either loosen the lock nut and remove the bolt/threaded shaft on one end of the shifter rod and then loosen the locking nut on the rod at one end (or both ends) of the rod and turn it to lengthen or shorten (increase or decrease) the rod length on one or both ends of the linkage rod until you get it where it just fits into the shifter arm hole(s) again with the pedal sitting where you want it be, re-install all hardware and tighten all hardware etc. If you want the pedal height above a floorboard or if you otherwise just want to adjust the pedal height/position you would not adjust the shifter rod linkage but would loosen and remove the pedal arm and re-position it where you want it and then re-install it and tighten its hardware again etc. Of course you could adjust the pedal height in a small increment by adjusting the shifter linkage if the placement on the pedal rod serrations does not align the pedal close enough to the precise location you want it to be at.
Sep 29, 2012 | 2009 Harley Davidson FXD Dyna Super Glide
2003 FJR 1300 clutch adjustment
Hi, Darrell_kauf and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Clutch Adjustment Technical Mechanical Problems
How to do clutch soak or replacement on Yamaha FJR 1300cc Second generation
Yamaha 2003 FJR1300 Service Manual
OEM parts for Yamaha
Yamaha FJR1300A Owner Manual
Feb 08, 2011 | 2003 Yamaha FJR 1300
2000 harley davidson softail custom 3,500 miles on stock motor when in 3rd gear trying to downshift into second it goes by it right into nuetrual??? why its annyoing
It should not do this. Evidently, there is something amiss in the shifting portion of your transmission. I would try adjusting the shifter pawl first. This adjustment is not difficult but requires a specail tool with which to get onto the adjustet. The adjuster is on the left side of the transmission just forward of the shifter shaft lever. It is behind the outer primary which makes getting to it difficult without the special tool.
To check it, with the engine off, gently depress the shifter lever downwards like you are going to shift into low gear. Depress until you feel the shifter pawl engage the shifter drum cam and is beginning to shift the transmission into gear. In other words depress the shift lever down until you feel it bump but don't shift it into gear. Then, do the same thing lifting the lever up like you are going to shift into second. Does the lever travel the same distance downward as it does upwards. If not, the shifter pawl needs adjusting.
If this is not the problem, you may have to remove the transmission top cover. With the cover off, you can see the adjustment of the shifter pawl. You may have a problem with the shifter pawl itself or the detent ball may have a problem.
At any rate, it should be something that can be repaired without a major disassembly of the transmission.
Good Luck
Steve
Jun 27, 2010 | 2003 Harley Davidson FXST Softail Standard
Revtech 5 speed tranny. Transmision some times will get stuck in inbtween 5th gear and 4th gear, I would have to try and shift up and down from 5th to 4th, 4th to 5th and some times it would shift down on...
Sounds more like a shifter pawl problem. I'm not familiar with the RevTech tranny but it should be very similar to the original H-D tranny. The shifter pawl has to be adjusted so that it's got equal travel in both directions. If you're trying to adjust it. Put the tranny in neutral. Now lift the shifter lever until you feel the pawl engage the pin in the shifter drum. Then go back to the middle of the movement range and depress the shift lever until you feel the pawl contact the other pin. The lever should move about the same distance in each direction. If not, the shifter pawl needs to be adjusted. On some bikes, it take some special tools to be able to get to the adjuster. The adjuster is on the left side just in front of the lever that connects to the shifter pawl shaft sticking out of the transmission.
May 29, 2010 | Harley Davidson FXST - FXSTI Softail...
Reverse doesn't work
You need to adjust the linkage so that it goes forward only when it is in FORWARD then reverse will work
Sep 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Shifter issue?
Hi their.Yes there is a place that's not to hard to adjust. Underneath the truck on drives side there is an adjustment there.Make sure nothing was broke in the slamming on the shifter..
Mar 29, 2009 | 1996 Toyota 4Runner
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
