Question about Metra 40-cr10 2006-2008 Chevy Impala Lt Antenna Cable Car Audio Radio Stereo
Solution to fix p1811 codes - Metra 40-cr10 2006-2008 Chevy Impala Lt Antenna Cable Car Audio Radio Stereo
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 808 Answers
Maximum adaptive strategies long shift this is a transmission code for a hydraulic pressure fault.
Posted on May 15, 2014
CODE P1811
P1811 - Maximum Adapt and Long Shift Mode Chevy, Pontiac, Saturn, and Buick Front Wheel Drive Vehicles The P1811 code is one of the most common codes for transmissions in 1997-on GM front wheel drive vehicles. Symptoms of this code include a check engine light illuminated and harsh shifting. Cycling the key on and off may cure the harsh shifting until the criteria for the code is met once more. We are going to cover what causes the code to set and repair options.
Code Criteria
If a shift into any gear other than reverse and forward engagements takes longer than 0.65 seconds to complete, code P1811 will set. The Powertrain Control Module will then command maximum line pressure inside of the transmission, resulting in harsh shifting. The PCM will also command the check engine light or service engine soon light to be illuminated when P1811 is set. Basically, the PCM is sensing a slip, and is increasing line pressure to maximum in order to prevent the transmission from hurting itself further.
Repair Options
In 2002, GM release a technical bulletin for the P1811 code. See the bulletin by clicking this link http://bit.ly/P1811_Bulletin. The bulletin states that a mechanical problem in the Pressure Control (PC) solenoid, contamination in the valve body, or incorrect fluid level can cause the P1811 to set. Those problems could definitely cause a P1811, but what they failed to mention in the bulletin is, what exactly is the PCM looking for when setting P1811. It's looking for a slip of 0.65 seconds or longer to set the code. See http://bit.ly/P1811_Diag_Tree. So it's not as cut and dry as the bulletin makes it to be. A burnt clutch pack, stripped overdrive clutch hub, worn accumulators, worn valving especially the actuator feed limit valve, and just high mileage can all cause this code to rear its ugly head. All of which would require transmission disassembly to repair. Now I'm not saying that P1811 is going to require a major transmission overhaul every time a vehicle comes into the shop with the code. I'm saying that it is not always going to be as simple as just changing out a solenoid.
How to Know if a Solenoid will Repair the Problem
It is impossible to know for sure what the internal shape of a transmission is while the transmission is still in the car. The first thing to check is the transmission fluid. If the fluid level is low, add automatic transmission fluid (ATF) until full. Remember that transmission fluid needs to be checked while the engine is warm and running with the shifter in the Park position. After the fluid level is OK, drive the vehicle to your nearest People's Transmission certified shop to have it checked. If the fluid level was low, there is a leak somewhere that has to be repaired. The shop will then test drive the vehicle while monitoring data on a scanner that is communication with your vehicle's PCM. After that, the shop will most likely recommend a pan drop to see if any contamination is being produced inside of the transmission. If contamination in the form of clutch material or metal is present, then a solenoid replacement will be a waste of money. If the pan is clean, fluid is in decent shape, and the mileage is below 80,000 miles or so, then maybe a solenoid will fix the problem. The thing to remember is, if the shop recommends a solenoid, then they are looking out for your best interests. It still may not fix the problem, but from what they have seen during their checkout, a solenoid replacement is worth the gamble. If the shop recommends a transmission overhaul, ask them what they found that makes them think that is the only option.
Maybe this will help, good luck.OKI1IT
Jan 06, 2016 | 2008 Chevrolet Uplander
Code p1811
Took me 10 seconds to find all sorts of web sites on P1811
Type: Olds OBD P1811
Mar 29, 2014 | 2000 Oldsmobile Silhouette
My 2001 pontiac bonneville has code p1811 is it serious
That's a manufacture code
Have to Google it
2001 Pontiac Bonneville OBD2 P1811
Mar 27, 2013 | Cars & Trucks
Code PO420A, PO742A,P1811C
P0420 catalytic below threshold,Your basically dealing with is a failed catalytic ,
P0742 Torque convertor clutch circuit stuck on or off.
P1811 this is manufacutrer code definition adaptive shift (due to P0742)
P1811 this code is set from towing a trailer in overdrive
when P0742 comes on it usually is accompanied by P1887
If its p1811 then yes it truly is a TCC solenoid being a problem As for catalytic code te catalytic is a mechanical device and yes they do expire from mileage and age
Mar 07, 2012 | 2002 Buick LeSabre
Could you tell me some of the things that may set off the following codes P0742, P1573, P1811
P0742 - Torque converter clutch solenoid circuit stuck on
P1573 - Connection lost between ABS Module and PCM
P1811 - code P1811 will set if a shift into any gear other than reverse and forward engagements takes longer than 0.65 seconds to complete
Mar 02, 2012 | 1997 Buick Riviera
My 2003 impala was diagnosed and it came back with two codes and they are p0742 and p1811.
code po742 torque converter clutch circuit stuck on conditions. code p1811 maximum adaptive and long term shift conditions.see this code transmission fluid is low and contaminated.change transmission fluid and filter see if this help your problem.you need to fix this problem fast transmission is not getting enough fluid to work.
Apr 02, 2011 | Chevrolet Impala Cars & Trucks
Metra 40-cr10 2006-2008 Chevy Impala Lt Antenna Cable Car Audio Radio Stereo Logo
151 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
