Question about DSC Home Security
How to disable a DSC motion detector - DSC Home Security
2 Suggested Answers
  • 16 Answers
SOURCE: Paradox 525D Motion Detector wiring up
nc c + - Y G Tmp Tmp
nc and c is relay output normally closed
+ and _ is 12vdc input
Y and G is bus connection
Tmp is tamper output also normally closed
Posted on Apr 13, 2010
Why is the LED light completely off after the walk test and lockout time?
Yes, it works normally. Things have evolved in the technology of security systems and now it is standard to have any LED turned off on any motion detector (the LED's are now used for walk-testing only), the standard DSC and Honeywell wireless motions also do the same thing.
  • This is a normal function for your motion detector. It's also a great power saving function since most of the current draw on the batteries is when it's transmitting a detection signal so if you're home and moving around it will only transmit every few minutes instead of every second, saving on battery life significantly (up to 5 years on average) but after the 3-minute lockout the passive infrared scans continuously until it transmits another motion signal.
Reason: most burglaries are done by someone who has been there before, if they see the LED then they know the motion will catch them moving in that given spot, then they can "map-out" where it's safe to walk (where the LED doesn't light up) for when they plan to return for a robbery.
You can also make this device "more sensitive" by moving the jumper pin position by the right side battery and having the back mounting plate mounted using the bottom screw presets so it faces slightly downward instead of straight forward.
Helpful tip: Change the batteries every 4 years if you're using Alkaline (dead or not) since the detector was engineered "too energy efficient" and the batteries actually leak and corrode the interior PCB at about the 5-year point on about 15% of the detectors with factory original duracell batteries (from what I've experienced in field service).
Apr 06, 2015 | Interlogix GE SAW Wireless Indoor PIR...
Tip
How to Operate a Home Security System Without a Contract
Many homes have alarm security system installed, even though the current tenants may not have been the ones who paid for it. Some did pay for it but just can't afford the high monthly cost of alarm monitoring. Many people don't realize that once the alarm security system is installed only the monthly monitoring fee stands in the way of free home security. The alarm system still works without monitoring, and it is easy to configure on your own.
  • Install the dial capable motion detectors in place of the entryway motion detectors. The mounting directions and hardware will be included in the motion detectors' packaging. Often the old motion detector's hardware will mount the new one.
  • Connect phone lines to the new motion detectors as instructed by the manufacturer. Usually the lines connect from the new motion detectors to a phone or third-party dialer.
  • Program the dialer or the dial-capable motion detectors to dial the phones of your choice. Your cell phone is usually the most important phone number to program into the dialer to alert you quickly if there is an intruder.
  • Arm the alarm as you normally would. If there is an intruder, the new motion detectors will sense the movement and will dial your phone to alert you.
  • Tips & Warnings
    • Consider replacing the motion detectors that cover the windows and alternate entry and exit points, especially if you have a large home or one with several different entry doors.
    • If the dialer-enabled motion detector is capable, program a second and third phone number into the dialer to maximize effectiveness. Dialing your cell and your neighbor's home phone, for example, would be more effective when you are away from the area.
http://www.securityalarmchina.com/
on Mar 29, 2016 | Home Security
How do I turn off the motion detector on my dsc3000rk keypad
see the below link and have a look at the door chime setting. turn it off as instructed and it should sort out your problem.
http://www.myalarm.com/manuals_prog/pc3000p.pdf
Oct 25, 2013 | DSC Home Security
I have a Bravo 3P pet immune PIR and it says on the connector that the contacts are normally closed. Unfortunately they are normally open. Is there something that I am missing? Even the specs on the...
To work properly, this unit has to have normally closed loop circuit. With power applied, and no motion in its sight, should measure 000 ohms (plus any resistor value in series). When activated..the contact should show infinite resistance(open).
You are only missing something if you're testing it with you in the the motion area.
Trash it otherwise.
Aug 20, 2011 | Bravo Sports Dsc Bravo 3p Pir Motion...
How to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
Jan 28, 2010 | Cooper Wiring Devices Motion Sensing...
Since the VEO motion detector is no longer available, will another motion detector product work?
The motion detector is available new on Ebay right now from an electronics surplus dealer. Just type in 12v motion as your search and at least half a dozen come up. I bought one and it was new in the box with the instructions.
Sep 16, 2009 | Veo Wireless Observer XT Network Camera
Dsc sensor not operating properly. I want to change it, is this very difficult? Thank you.
You don't mention what type of sensor. I assume it is a motion detector. Before replacing I would strongly suggest you first remove all power from the system by disconnecting the backup battery inside the control panel then pull the system's power transformer which should be plugged into an electrical outlet nearby. You will know that all power is removed by looking at the keypad - all lights on the display are off. Next remove the motion detector's front cover. Some detectors have a small screw on the bottom so that when removed the cover pops off. Others need to be opened using a flat blade screwdriver and prying off the cover. Once the cover is removed there should be a 4 conductor wire that is wired to a series of terminals. Observe the polarity of the wires, disconnect them and remove wall mounting screws. Install new unit. Be sure when wiring to connect power wires correctly. The 4 conductor wire should have a red (positive) wire and a black (negative) one. Connect the red to the + or pos terminal and the black to the - or neg terminal. Read the instructions that came with the new unit if in doubt. When finished plug the power transfomer back in then reconnect the battery (in this order). If power is connected properly the motion detector's red walk test light (indicating motion) should light whenever you walk in the protected area. Also make sure the system recognizes motion by first closing all protected areas such as windows and doors to get a system ready or green light indication on your keyad, then walk around the protected area. A properly working detector will show you a fault on the keypad everytime the system senses motion.
Sep 11, 2009 | DSC Home Security
CANT OMMIT ZONE
I don't know how this question got classified under Windows Desktop PCs, but it sounds to me like it's about a home burglar alarm system.
The feature you're looking for is typically referred to as "stay" or "bypass." "Stay" is used to automatically disable detection on preconfigured interior zones, such as motion detectors or photobeams so you can walk around inside your home without setting off the alarm. "Bypass" is used to disable detection on any individual zones you desire (except fire detection devices such as smoke detectors, heat detectors, and pull stations).
Every alarm systems works a little differently, but if you could get back to us with make and model, we could provide specific directions.
Also see our Website at MaverickSolutions.biz/solutions_sec.htm if you'd like more information about professional upgrades, changes, or reconfiguration of your alarm system.
Apr 14, 2009 | Computers & Internet
Electrical hook up for 2 motion detector lights so both lights operate when either detector is activated (dual master system)
yu can't do it with off the shelf detector. Sine the detector is single input.
you need serial and parallel input to the device.
you need to get commercial detector that haev serial and parallel input to the detector.
Dec 15, 2008 | Solar Motion Security Light Conversion...
Home Security Logo
111 people viewed this question
Top DSC Home Security Experts
yobo007
yobo007
don1956
Level 1 Expert
Terry Weaver
Terry Weaver
Are you a DSC Home Security Expert? Answer questions, earn points and help others
