Question about Baby Gear
I bought a pop pram about 3 months ago and the wheels are clicking can i replace them?
  • 10,865 Answers
Hello. You can contact Zooper directly at 1-888-742-9899 or info@zooper.com
Posted on Jun 23, 2009
96 mercury sable wagon popping noise
What about the strut mounts. Have the ball joints be checked. If u gas the car does it pop? Or maybe a wheel bering if its really loose.
Jun 16, 2012 | 1996 Mercury Sable
Where can I get replacement rear wheels for Mountain Buggy Urban pram?
check out
http://www.pushchairs.co.uk/acatalog/miscellaneous_spares.html
Dec 08, 2011 | Mountain Buggy Urban Single Stroller
The pram has only been used for 6 months and the back wheels are now worn out. i basically would like to know where i can buy replacements for it?
Good Afternoon
You can purchase replacement rear tyres, innertubes, or complete rear wheels via your local Quinny retailer.
May 02, 2011 | Quinny Buzz Three Wheel Stroller
Shaking when driving. bought new tires in front 18 months ago. bought the car 3 years ago it was already lowered bought back tires six months ago had alighned two months ago started shaking after and tires...
get under the vehicle (use ramps) and check all linkages for movement pull push on the anti roll bar links, pull push on steering rack and pinion and linkages, any excessive movement, jack each wheel at a time, using a bar check the lower wishbone joints for movement, get the bar in the gap between the wishbone and lower part of the shock. and pull down, if any movement in ball joint up and down replace. while wheel on vehicle check for movement in bearing you will feel a tiny amount not much but pull and push on wheel with opposite hands on 12 o'clock and 6 o'clock and do the same at 9 and 3. now with both wheels off the ground but with the tyres still on, have some one holed one wheel and push pull on wheels each side there should be even movement between both wheels, if everything is fine with the the steering linkages and this dose not feel or sound right then this could be the problem also to add if the inside and out side of the tyres are wearing then the tyre pressure is wrong and needs adjusting to the right tyre pressure .
Jul 24, 2017 | 2000 Ford Mustang
We bought a britax strider 3 wheeler pushchair, in january for our granddaughter, my daughter lost receipt moving house, the rear wheels on the pram are wearing uneven, causing the pram to have a wobble...
the strider is now made by 2 different companies
1, uppababby model vista 2009 have a uk based helpline http://www.uppababy.co.uk/contact-us.html
2, abc designs model cobra
http://www.abc-design.de/en/service/contact.html
I have found this out as I am using my strider for my new baby I can now use a carseat and carrycot with the adapters available from these companies
hope this helps
Sep 23, 2010 | Toys
I have a AT3 dog stroller by pet gear and one of the rear pram wheels is damaged i am wondering if there is a way to get a new one?
i would type in Buck Pet Gear AT3 al terain 3 wheel replace wheels if that doesnt work try with the place you bought it from
Jan 31, 2010 | Buck Pet Gear AT3 All Terrain 3 Wheel...
Need 4 replacement wheels for an emmaljunga pram,can you tell where i can find them?
I have 8 extra Emmaljunga wheels for sale - 4 black inflatable and 4 white rubber. I would like to sell them asap! Contact me if you're interested!
Jun 25, 2009 | Emmaljunga Coronado Stroller
New wheel in instep duo stroller needed (BACK WHEEL)
I should go to he Pram Shop where you bought it from, if it has closed down go to a Mothercare Shop or similar Pram Shop. They will be able to get you the information you need.
Apr 08, 2009 | InSTEP 10K Single KA106 Jogger
Navy and white silvercross dolls pram bought 1980 new
I know exactly what you mean about the classic Silver Cross look but if you fit two larger diameter wheels the pram would not sit level unless one of the axles was repositioned to compensate.
Wheels have been retained by a number of methods and then hidden behind a (usually) chrome cap that must be carefully prised off. In more modern times it has become usual to combine the chrome cap with a spring retainer. It is fitted with the gentle tap of a mallet but patience is needed to remove it and no small amount of carefully applied force and even then there is about a 50% breakage. It is possible your pram used these.
Apr 18, 2017 | Baby Gear
Valco pram repair
Hi there.
If it is a plastic moulding that has stuck, use a silicone spray (mr sheen will do) to release it.
If this will not help at all, try your nearest Halfords bike department or bicycle repair shop. I doubt they will charge you anything.
If it is a broken part, find the manufacturer for ordering a replacement.
Hope this helps,
Jun 11, 2008 | Valco Baby Gear
Baby Gear Logo
43 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
