Question about AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner
Why are the wheel not moving? - AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner
    Top Expert:
  • AquaVac Master
  • 8,471 Answers
Bad drive motor or belts
Posted on Feb 15, 2018
Telescopic steering wheel wont tilt
Telescopic steering wheel stopped moving - MBWorld.org Forums
mbworld.org/.../225749-telescopic-steering-wheel-stopped-moving.html
Jan 9, 2008 - Telescopic steering wheel stopped moving ... If it won't move at all, and you don't even hear a motor, it could be a fuse; check your fuse diagram ... Steering wheel adjustment motor gone bad?
Jan 28, 2008
HOW TO: Fix power steering column that will not move up and ...
Jul 12, 2007
More results from mbworld.org
Fixing the Power Steering Wheel of a Lexus LS400 - YouTube
? 2:15
https://www.youtube.com/watch?v=NP8YmnGRXWU
Jan 4, 2012 - Uploaded by AutoTech USA
If your power steering wheel is no longer working; moving up and down, back and forth, and when you attempt ...
telescopic and tilt steering not working - Cadillac Forums
Dec 01, 2015 | Cars & Trucks
Why won't my old manual singer sewing machine needle move?
1. Disengage the bobbin winder.That is done by moving the arm away from the center wheel. 2. Tighten the hand wheel. When you tighten you should have resistance like a jar has. If this doesn't then continue. 3. Loosen the small screw attached to the hand wheel center lug. Now, move the hand wheel into a position where it will tighten. 4. Go ahead and tighten the small screw. Now, it should move.
Nov 19, 2014 | Singer Sewing Machines
Steering wheel move hard
low power steering fluid, faulty steering pump, or faulty rack/pinion.
Dec 15, 2013 | 2002 Buick LeSabre
Driver side wheel doesnt turn while moving steering wheel
If what you stated is true, then an answer here is useless since you would have not been able to drive this vehicle after that, and have had it towed and repaired.
Aug 26, 2012 | 2001 Dodge Ram 1500 Truck 2WD
I have a 2001 dodge stratus and the key wont turn
Have you tried moving the steering wheel while trying to turn the key? Many times when you lock the ignition there is pressure on the steering wheel lock. That pressure against the lock can prevent the key from turning. Move the wheel one way then the othe while turning the key. You may need to move the wheel with a lot of force. The wheel will move more one direction than the other. Hold force on the wheel when turning the key. If that is the problem the key will turn easily when the wheel takes the pressure off the lock. Good Luck.
Thanks for using FixYa.
Gaker
Jul 27, 2011 | Dodge Stratus Cars & Trucks
My steering wheel locks up when I put it in park, and when I try to restart it, it won't crank. The key won't turn. What do I need to do?
grab the steering wheel and turn it left or to the right and sometimes you might have to put a little effort in it but one way the steering wheel will move about 1-2" and as you are moving it with one hand take the other hand and turn the key and it should turn a lot easier.this is a common thing and if you can try to have the wheels straight and try not to use the steering wheel to get in or out of the vehicle and the wheel should not lock and make it so hard on you.you have to use both hands at the same time one moving the wheel and the other one turning the key but start moving the wheel in the in direction that it moves the most then turn the key.
Jun 17, 2011 | 1999 Toyota Sienna
Toureg problem. On day...Shuttering coming from rear of vehicle. Felt like tire was flat, pulled over to check. Tires ok, wheel bolts ok, went underneath and everything is tight, attached and no leaks. ...
COULD BE BAD REAR AXLE SHAFT BEARING.WITH VECHICLE IN THE AIR GRAB WHEEL TOP AND BOTTOM TRY MOVING THE WHEEL IF WHEEL MOVES WHEN YOU SHAKE IT.THE REAR WHEEL HUB BEARING IS BAD.WHEN YOU SHAKE WHEEL WITH HANDS SHOULD NOT MOVE,WHEEL SHOULD BE SOLID AND FIRM.
Apr 18, 2011 | 2004 Volkswagen Touareg
How to explain one sixth turn of an object
Imagine you are looking at a wheel from the top. There is a notch on that wheel. When you turn the wheel, the notch will move along the circular path of that wheel. When the notch moves completely in one whole turn, it has moved 360 degrees. Remember there are 360 degrees in a circle.
When the notch moves only around half of the circle, it has moved only 180 degrees. The notch should be on the opposite side it started on.
One 1/6 of a turn will be equal to 1/6 of 360 or 60 degrees. So the notch will have only moved 60 degrees if you turn the wheel 1/6.
Nov 11, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
Kenmore 10 stitch needle won't move
hi there,
push or pull hand wheel clutch to engage
motion of needle and shutter.
if not check belt on downside of hand
wheel open cover motor,loosen bolt cover
see belt check if engage on pulley by
holding hand wheel move belt if
hand wheel move,if not tighten screw on
pulley from hand wheel and moter.
have a nice day and thanks
Apr 03, 2009 | Sewing Machines
AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner Logo
70 people viewed this question
Top AquaVac Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Steve Slater
lioneltrain5
Level 1 Expert
Are you an AquaVac Pool and Spa Expert? Answer questions, earn points and help others
