Question about Ritter TYPE 75 F Exam Chair
Roof wont work on mercedes 230 slk quarter window wont drop so is that why roof wont workup or down
I've just purchased a 2008 SLK 200. Does anyone know how to put the rear quarter windows up whilst top down.
I have a CLK 2001 and my rear window buttons just work normally when the roof is down. I can even raise a rear window without raising the front one.
https://www.mbusa.com/mercedes/service_and_parts/owners_manuals
Mar 09, 2017 | 2008 Mercedes-Benz SLK 200
1998 slk 230 can the boots central locking alignment interfere with the operation of the roof closing
your windows move first , check fuses and clean your window may be sticking due to dirt.
Jan 20, 2015 | 1998-2004 MERCEDES SLK230 SLK 230 CARBON...
What to check when a SLK 230 1999 Convertible top will not open?
dont know much about convertible mercs but there should be a relay which would send power to the motors if this has blown the lid would not lower or fuse or the terminals in the switch its self are still wet
Sep 08, 2014 | Mercedes slk 230 kompressor fuse. lock. ....
Electric windows are fine the roof gets half way
If the top is half way down that means that the trunk is open and should be touching the trunk switch to continue the process. The switch must be bad and it is inside the rear right fender close the the stop light
Jul 25, 2010 | 1999 Mercedes-Benz SLK
Just but an Mercedez SLK 230 Kompressor 1999 and the hard top will not go down.
First check that you have oil on the hydraulic pump that it is inside the trunk on the rear right fender the oil should be between the marks. If thats ok check when you put the ignition on if the switch that operates the roof is on, should be off, on means that something is wrong, if blinks 6 times one of the 5 or 7 switchs are not closed, check one by one. check the two that close the trunk at the middle, the cover, the trunk limit switch, the trunk switch
Apr 08, 2010 | 1999 Mercedes-Benz SLK
My slk 2000 roof has just stopped working. It wont go down at al
Sounds like maybe some pin switches for interlocks have gone bad. Open your trunk and look for the rubber booted switches and try holding them or shorting them, if you make the top move it shows you which ones are bad.
Jul 16, 2009 | 1999 Mercedes-Benz SLK
Sticking roof
This symptom almost always points to a lubrication issue. The SLK hardtop is notorious for needing to belubricated every couple of years. Here is a link with directions andphotos:
http://www.benzworld.org/forums/r170-slk-class/1426014-lubing-vario-roof-pics-1-krytox.html
Mark Andrews
Mar 15, 2009 | 1999 Mercedes-Benz SLK
Mercedes slk roof problem
hi,seem only adjustment of micro switch,but you need a tester(handheld tster) only a dealer have,
Mar 02, 2009 | 1999 Mercedes-Benz SLK
2000 MERCEDES SLK ELECTRIC ROOF PROBLEM
hi,seem only adjustment of micro switch,to detect which switch are need to adj.you need to send to dealer.
Jan 18, 2009 | 1999 Mercedes-Benz SLK
Slk 230 komp
1. Try cleaning the front brake senor.
2. Replace brake switch (under dash).
3. Check front brake pads for wear.
Jun 10, 2008 | 1999 Mercedes-Benz SLK
Ritter TYPE 75 F Exam Chair Logo
336 people viewed this question
Top Ritter Medical Experts
Electro Med Services...
masud
masud
Are you a Ritter Medical Expert? Answer questions, earn points and help others
