1998 Mercury Mountaineer Logo
John Beard Posted on Jun 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The display on the factory dual media audio system does work.
Display will not show text, station or time.
Anonymous
Level 3:
  • Master 1,297 Answers
  • Posted on May 19, 2010
Anonymous
Master
Level 3:
Answers
1297
Questions
0
Helped
529333
Points
3746
Older radios had a bulb you could replace, pre-1990
however, now the displays are true LCD and the radio will need replacing
Why will the "TEXT" feature not work on my dashboard radio?
find the source button to change the mode and what you want will come up. It will be in the USB, I-pod or some such media .
1helpful
Audio System Problem
Check wiring maybe some of wires have worked loose.
1helpful
I accidently did something the display for the clock/radio ??!!! the display previously show time display & now it shows the radio station name RE: the radio station I listen to is 105.7 (KHCB) and ...
continually press/release the center of the tuning know until you have the preferred display you want and then press and hold the same button until the system beeps (1-2 seconds). It will now save your preferred default screen (clock in your case)
5helpful
How do I set the clock in my 2006 Equinox... nothing in the manual
check page 3-39
Setting the Time
To set the hour, press the clock button. The clock
symbol will appear on the audio display and the hour
number will flash. Then turn the ADJ knob to increase or
to decrease the hour. To set the minutes, press the
clock button again. The minute numbers will flash.
Then turn the ADJ knob to increase or to decrease
the minutes. The time can be set with the ignition on
or off.
To synchronize the time with an FM station broadcasting
Radio Data System (RDS) information, press and
release the clock button to enter the clock set mode,
then press and hold the clock button for three seconds
until UPDATED appears on the display. If the time
is not available from the station, NO TIME UPDATE will
appear on the display.
RDS time is broadcast once a minute. After tuning to an
RDS broadcast station, it may take a few minutes for
the time to update.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
3helpful
2answers
I have a 04 acura and the lights in the radio clock an heat controls does not work.
ACURA Service Bulletin
04-021
Applies To: 2004 TSX - From VI N JH4CL9...4C000001 thru JH4CL9...4C028982
July 9,2004
Audio-HVAC Display Module Is Dim or Dark
SYMPTOM
The audio display and controls (knobs, buttons, bars)
of the audio-HVAC display module are dim or are dark.
PROBABLE CAUSE
Faulty audio unit.
CORRECTIVE ACTION
Replace the audio unit. Refer to S/B 87-015, Audio Unit
In-Warranty Exchange/Out-of-Warranty Repair.
If a client calls ahead to schedule an appointment, and
the vehicle is in the affected VIN range, order the
remanufactured audio unit right away so it is available
when the client comes in.
PARTS INFORMATION
Order the appropriate replacement audio unit:
NOTE; The audio unit is listed as a Tuner Assembly in
the Interactive Network (/N) Parts Catalog. This unit is
both a tuner and a 6-disc CD changer.
Tuner Assembly (without navigation system):
P/N 39175-SEC-A02RM
Tuner Assembly (with navigation system):
P/N 39175-SEC-A82RM
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies
Operation Number: 010149
Flat Rate Time: 0.5 hour
Failed Part: Use the RM part number (from the
repair order) without the RM.
Example; 39175-SEC-A01
Defect Code: 03214
Symptom Code: 03272
Skill Level: Repair Technician
Out of warranty: Any repair performed after warranty
expiration may be eligible for goodwill consideration by
the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a
decision, before starlina work.
REPAIR PROCEDURE
1. Go to S/B 87-015, Audio Unit in-Warranty
Exchange/Out-of-Warranty Repair, for guidance on
how to get the remanufactured audio unit.
2. if you can read the audio display, write down your
client's radio station presets.
3. Remove the audio-HVAC display module (see page
22-267 of the 2004 TSX Service Manual). (In ISIS,
use the keyword DIS MOD, and select Audio-
HVAC Display Module Removal/Installation frorn
the list.)
4. Remove the faulty audio unit from the audio- HVAC
display module (see page 22-268). (In ISIS, use the
keyword DIS PAN, and select Audio-HVAC
Display Panel Removal/Installation from the list.)
5. Transfer the left and right brackets from the faulty
audio unit to the remanufactured audio unit. If the
remanufactured unit has a shipping cover and
shipping screws, make sure you transfer them to
the faulty unit being returned.
6. Install the remanufactured audio unit in the audio-
HVAC display module. Then reinstall the audio-
7. Enter the anti-theft code for the new audio unit.
Enter your client's radio station presets if you
recorded them in step 2.
8. Make sure all of the functions of the audio unit and
HVAC work properly.
9. Replace the sticker on your customer's anti-theft
radio identification card with one of the new stickers
that show the anti-theft code. Apply the other
sticker that shows the anti-theft code onto the
vehicle history file copy of the repair order.
10. Remove all old serial number stickers from the side
of the glove box or inside the center console. Then
apply the new sticker that shows only the serial
number to the side of the glove box.
11. Return the faulty audio unit to the parts
department. Refer to S/B 87-015 for parts return
in structions
2009 Escape. When I purchased this year, I mostly listened to regular radio, which showed artist and title in display. Now, after playing Sirius a lot (which shows text info on display), the info no...
Does it do this on all radio stations? Some stations don't broadcast that information, some do. Also there may be an info button somewhere on the radio, try pushing that to see if it comes up.
2helpful
2answers
In dash display with clock,radio station indicator and outside temp.doesn't work,just all of sudden...Everything else is O.K.
My audio and clock display stopped working all of a sudden. The audio system still worked fine. I had all my fuses checked previously and was told it could cost up to $800 to fix by Mazda. I pulled out fuse 31 and wiped it clean, reinserted it and now my display works as good as new. Thanks to those on this site for your help.
SMS
Text button does not work
When you insert a cd that has folders of MP3's it's suppose to display the music info., IE., artist, album,
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
