Question about Troy Bilt 5.5hp Self Propelled Mower
My lawnmower won't start
My Troy bilt lawn mower won't start. I put oil in the lawn and gasoline and prime it 5x's. What can I do to get it started. My lawn mower is only two years old.
My lawn mower has a new battery but will not start
Posted on Nov 02, 2009
    President:
  • 3,113 Answers
Clean air filter and replace spark plug. If it is wet when you pull it out let it sit and dry out before putting new one in.
Posted on Jun 23, 2009
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
My troy bilt lawn mower does not want to start like it loses priming. Can I reprime manually
if it has a bulb pump it about 20 times if not you could spray a little starting fluid in the air filter or take filter off and poor a little gas in the carb
Aug 03, 2013 | Troy Bilt 5.5hp Self Propelled Mower
My Briggs and Stratton lawnmower engine won't start. Checked for air, spark, and fuel problems.
Before doing too much more i would pull the flywheel off and check the key has not part sheared.
Jan 28, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Troy-bilt 550 series mower won't start. I've only used it twice.
does it crank over?did you leave the blades on?are you pushing on the brake pedal
May 25, 2012 | Troy Garden
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
How do you prime a troy bilt 675 pressure washer
if you dont see a primer bulb then you must start it in choke mode after running out of fuel
May 31, 2010 | Garden
My Troy Bilt Self Prop. Z-start won't keep running. I clean All, replace Filter and Plug, have clean gas and lubed all. It Starts for 2 seconds and then cuts off. What do you think it could be? Thanks....
I had the same problem, Tilt the lawnmower on it's side air filter facing up and remove air filter cover and air filter then remove the fuel bowl underneath the carb; then clean the fuel bowl with some gas and a clean rag. For the next step be sure to aim blower tip at target then look away before pressing trigger, this will prevent gasoline form getting into your eyes.Take an air compressor and carefully clean out the carb where the flap is and the tube where the fuel float that would rest inside fuel bowl is. Leave on side install everything back except for air filter and cover. Then pour a little gas in the carb to prime it, lay the lawnmower back on all 4 wheels and try to start.
Aug 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Changing oil
is the drain plug on a troy bilt 6.5 hp ontop of the blade in the right hand cornor
Apr 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
1,787 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
