Question about Toshiba 32HLC56 32 in. HD-Ready LCD Television
No sound from hdmi input for my xbox360 - Toshiba 32HLC56 32 in. HD-Ready LCD Television
How connect to BenQ mp620p- xBox360 ? Thanks good luck
If you've got the version with a DVI input, use a HDMI to DVI cable. That'll take care of picture but not sound. You need to hook up an audio cable that finishes in a 3.5mm stereo jack if you want to use the Benq's speaker.
If you have the older version with just a VGA input then buy an Xbox 360 VGA cable. You'll also need an audio adapter; 2x phono/RCA sockets going to 3.5mm stereo jack.
Sep 09, 2014 | BenQ MP620p DLP Projector
I want to connect my Philips HTS3357 Home Cinema System to my Panasonic PT-AE900E LCD Projector, How do I go about putting it altogether so it works with my xbox360/PS3
Generally speaking, if your Home Cinema system is able to pass-thru video as well as audio, you'll want to take the HDMI cable from the XBOX video out, into the Home Cinema system's input (any HDMI input should be fine), and then run the HDMI video out to your projector. Any other devices you want to be able to project as well (DVD/BluRay, PC, Cable, Satellite, etc.) would also be plugged into the Home Cinema system as "in" devices, like the XBOX.
When you want to display one of those devices, you would select that "in" port's input name in the Home Cinema system (for example, if the XBOX is connected to the HDMI in that is labeled "aux", you will switch the cinema system to Aux Input, and the projector should immediately begin getting the signal from the theatre system. To switch to another device, you simply change the Input channel on the Home Cinema.
The audio also, providing the device (the XBOX) can carry it on the HDMI cable, will also be delivered to the Home Cinema. Some devices cannot carry sound on HDMI (though many can). For those, you will need to run an HDMI cable for the video, and also an optical cable or other type of audio-only cable, for its audio. You do not need to run an audio cable to the projector though, as the projector is only for video. The Home Cinema will take care of the sound itself.
Mar 28, 2014 | Philips HTS3357/05 Theater System
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
My Mitsubishi WD-62627 has no pic/sound w/ PS3
you just have to keep switching the back button off and when u turn it back on hold the front power button till you get 2 beeps
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
I have a TX SR606, and I have an Xbox360,
In the setup menu go to HDMI setup and see if the HDMI inputs are set to IN1 or IN2 or IN3. If you are not proficient with the setup menu let me know and I'll be glad to send you some info from the owners manual on seting up the inputs.
Dec 08, 2009 | Onkyo TX-SR606 Receiver
MX 3950D Philips - PS3 no sound
Aside from the xbox360 working via the coaxial digital cable. I got the PS3 to work this way.
I had to use the supplied SCART > (Y-video) (Red-Audio) (White-Audio) cable. Basically plugged this in from the PS3 directly to the MX 3950D Aux (Auxiliary) audio input.
On the PS3 audio settings menu, switched from HDMI to the 3rd option SCART.
Turn on the MX 3950D and set to Aux. Bang, got sound again.
I missed this cause I "assumed" the video/audio cable that came with the PS3 was a HDMI to Audio/Video cable, and didn't even see the SCART port in the back of the PS3. So I thought I didn't want to lose 1080p ..etc etc. Anyways. MX 3950D still good =)
May 18, 2009 | Philips MX3950 System
Xbox 360, hdtv, surround sound assistance
Since the reciever does not show any picture use that hdmi input for the x box. and component inputs for the reciever.
Jan 23, 2009 | LG 42LG50 42 in. LCD HDTV
Looking to connect HDMI cable from dellW5001c to xbox360
192.168.15.1
i am appling this password. then username and password appling . plz help me
what is password and username.
Dec 27, 2008 | Dell W5001C 50 in. Plasma HDTV
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
Xbox connectivity problem
As dumb as this sounds here is the mistake Sony made. The receiver does not process sound from the HDMI, it will only pass through that data to you TV. So you will not be able to get sound from your 5.1 speaker setup if you only connect the HDMI, you have to use the matching audio input for that respective HDMI input. Make sense? So the HDMI DVD Input must have digital coax for sound, HDMI Video2 must have fiber optic for sound, and there is another fiber optic port for the Sat input. Yes thats right, if you have 2 HDMI HD components and each only has fiber optic(neither one has digital coax) you cant hook both up properly the way you would think. Sony made this receiver poorly, turning High Definition Multimedia Interface into High Definition Multimedia Except For Audio Interface.
Nov 18, 2007 | Sony STR-DG510 Receiver
Toshiba 32HLC56 32 in. HD-Ready LCD Television Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
